Help!!!
![Angry](https://www.jaguarforums.com/forum/images/icons/icon8.gif)
My 1998 model XK8 convertible failed it's MOT on Saturday because one of the four seat holding down bolts is missing. Can anyone tell me where I can find a replacement, as I understand the bolts are special?
Secondly the car failed because the Adamesh supplied LED headlights were wired incorrectly, i.e. when dipped lights were on, main beam lit, and vice versa. This problem I solved by cutting and rejoining the wires, problem solved.
I mounted my seat 1 1/4" to the Rear and had a Block made up to extend the Front of the Seat. I needed a Longer Bolt to replace the Standard one. They are available at most Hardware Stores:
![](http://my.execpc.com/B0/BE/pav/pav/JagBlock.jpg)
