Help! Broken plastic on Headlight
Today, while changing my bulbs, I accidentally broke the small tab that attaches to one of the bolts/nuts that holds the headlight to the body (the one near the bonnet). Now my headlight is dangling.
Do I really have to buy an entire headlight assembly just because of a tiny plastic piece?
Scroll down to post 62 in this thread: https://www.jaguarforums.com/forum/x...e-91230/page4/
You can use a pair of tin snips and some sheet metal to make a bracket, then clamp it tight with a good epoxy (like JB Weld) and let it set for 24 hours. Roughen the surfaces with sandpaper before gluing.
Thanks to Racediagnostics!
giandanielxk8 (06-03-2013)
Ok, I'll check for that.
One of my headlights is all glass, and the other one has the cutout for the washer separate from the rest of the glass. Anyway, do I want the headlight washer? Sounds like they're more of a headache than being useful.
While I'm at it, I noticed that the interior of the headlight's reflective coating can be easily removed. One of mine has sections of black in it which I thought was due to water. I do prefer blacked out headlights, will wiping the reflective coat off cause visibility problems?
1964Daimler
09-09-2015 11:28 AM
