HELP! Disconnected the battery and key won't open the boot
Old 11-24-2013, 04:20 PM
Windycityx's Avatar
Default HELP! Disconnected the battery and key won't open the boot
I had to disconnect the battery and I forgot the key won't turn fully to open up the boot.
I only have one key besides the valet key, which won't turn at all.
When I put in the master key and turn to the right, it stops at the point of where it would actually open, any suggestions? I have tried tapping the top of the boot like suggested
Old 11-24-2013, 04:29 PM
Windycityx's Avatar
Is this what I need to do? Do I just connect a + and - cable on different sides of jumper cables or do I use another car that is running to do this?
Under the hood, connect the battery (+) to the to the bolt under the rubber cover at the fusebox, and (-) to the chassis, as shown below with a set of jumper cables. Take care not to short the cable. Then open the trunk using the button. DO NOT START THE CAR THIS WAY.
http://i127.photobucket.com/albums/p...Rengine40c.jpg
Thanks to Paul Pavlik for this and GGG for the reference above..
The following 2 users liked this post by Windycityx:
aardvark64 (11-25-2013), Sandrahsfn (11-25-2013)
Old 11-24-2013, 06:56 PM
RJ237's Avatar
Received 2,801 Likes on 2,236 Posts
That's what you need to do. Always listen to Paul and Graham.
99xk8guy
05-28-2024 09:36 PM
JarodL
03-07-2024 01:39 AM
dsnyder586
04-04-2019 02:38 PM
Doovoe
XJ40 ( XJ81 )
09-06-2015 10:54 AM
philwarner
09-02-2015 11:45 AM
Quick Reply: HELP! Disconnected the battery and key won't open the boot
