Help on Excess Cooling System Pressure
Don't get crazy, and think worse case. Fix your fans first, you KNOW they are not working properly, there are two relays I believe on driver side lower down. Also while the cap maybe bad you may also have overfill hose plugged, the overfill is in drivers side wheel well front of tire, remove plastic well protectors and you'll see it (turn wheel all way right) Think Occam's Razor, simplest solution is often the right solution.
Well - it appears (GULP) that the cooling issue and excess pressure issue is resolved. After getting the cooling fans working properly by replacing a 1" section of corroded wire on the left fan connection the issue seems to be gone. I have put the car through a few test (translation = no revenue enhancement agents in site) and it passed with flying colors. Interesting note on the cooling gauge (idiot light equivalent), I have noticed that it now fluctuates slightly at the below 1/2 point position. Previous to the repair it was always holding steady at slightly above the 1/2 point. Now driving it at least once a week and have no issues since repair.
Thanks to all for your input.
