Help on Excess Cooling System Pressure
Old 11-30-2014, 04:37 PM
DaveInVA's Avatar
I would still do a leak down test. That might answer everything.
Dave
Old 02-01-2015, 08:19 AM
wheelmang's Avatar
Originally Posted by jamdmyers
Don't get crazy, and think worse case. Fix your fans first, you KNOW they are not working properly, there are two relays I believe on driver side lower down. Also while the cap maybe bad you may also have overfill hose plugged, the overfill is in drivers side wheel well front of tire, remove plastic well protectors and you'll see it (turn wheel all way right) Think Occam's Razor, simplest solution is often the right solution.
Well I finally got back to the cooling fan issue. (Not a daily driver so repairs are done as time allows) After replacing every fuse sensor and thermostat, some twice, I decided to pull the fans and do a bench test. As I was removing the connector to the left fan I felt some roughness on the bottom of the yellow and orange wire. There was about a 1/2" strip of wire insulation missing. Not a single strand of twisted wire was broken just corroded enough to prevent proper current flow. Totally invisible unless you removed the connector from the fan and turned it over. I spliced in a new 2" piece of 10 gauge wire, wrapped and water proofed it turned on the car with A/C = Two fans turning great.
The following 3 users liked this post by wheelmang:
Jon89 (02-01-2015), MRomanik (02-01-2015), RJ237 (02-01-2015)
Old 03-22-2015, 04:30 PM
wheelmang's Avatar
Default Excess Pressure Update
Well - it appears (GULP) that the cooling issue and excess pressure issue is resolved. After getting the cooling fans working properly by replacing a 1" section of corroded wire on the left fan connection the issue seems to be gone. I have put the car through a few test (translation = no revenue enhancement agents in site) and it passed with flying colors. Interesting note on the cooling gauge (idiot light equivalent), I have noticed that it now fluctuates slightly at the below 1/2 point position. Previous to the repair it was always holding steady at slightly above the 1/2 point. Now driving it at least once a week and have no issues since repair.
Thanks to all for your input.
1100me
07-24-2023 06:10 PM
toronadomike
08-07-2022 03:41 PM
johndahlheimer
09-16-2015 05:44 PM
fingers
09-08-2015 03:54 PM
1100me
09-07-2015 06:26 AM
Quick Reply: Help on Excess Cooling System Pressure
