Help identifying alloy wheels? - RESOLVED
I don't recognize it either as a standard Jaguar XK8/R wheel. Your best bet is to remove the wheel from the car and check on the inside of the spokes for any markings or part numbers. Check if there is a spacer. Check for evidence of machining on the hub. Take pictures and plug whatever you find in your favorite search engine.
Best of luck, keep us posted.
Stern Wheels - JoesShowroom.com - Performance Wheels, Tires, Classifieds, Galleries, Events & Models - Wheel and Tire Browser
cyber3d (08-08-2017)
Check out this note (#1) from Salo - he can probably tell you....Not exact but damn close...
https://www.jaguarforums.com/forum/x...7/#post1736589
Good luck.
Good luck.
Looking at your posted picture, I can see at the bottom of the rim, there are at least 2 markings within the 3 bottom rim bolts.
What do those markings say? ? ? I bet you can get an answer from Google...
Good luck!
Good luck!
