Help ! - Manual close of top
My top isn't fully closing. (I was driving a little too fast and it stopped duing the close sequence and won't restart the open or close sequence).
How do I get that plastic plug off that covers the area where I insert the allen wrench? I'm trying w/ a tiny flat screwdriver and don't want to break it.
Will the rear windows close after I manually close the top?
Yes the windows should close after the top is latched. To remove that plug you just need to use a larger screwdriver. Go to my page and you will see info on a how to http://www.gusglikas.com/AutoRepairH...lOperation.htm Let us know if you need additional help. Do you know why the top stopped closing??
You can go to my page http://www.gusglikas.com/autorepair.htm and see all the info I have on the roof operation and hose evaluation http://www.gusglikas.com/AutoRepairH...lOperation.htm and info on hose replacement if you elect to do it yourself http://www.gusglikas.com/RoofHoseReplacement.htm I hope this helps
99xk8guy
06-05-2023 06:28 AM
aholbro1
08-05-2021 05:02 AM
