Help needed interpreting fuel trims
Hi all
After owning my XK8 for three weeks and having some slightly hard transmission shift someone suggested I collect some fuel trim data. Today I collected the following at both idle and at 1500rpm. Parked up at operating temperature after a drive.
Idle
Bank 1 STFT 0.78%/LTFT 7.8%
Bank 2 STFT 6.25%/LTFT 0%
At 1500rpm
Bank 1 STFT 10.9%/LTFT 1.56%
Bank 2 STFT 6.25%/LTFT -0.78%
These look a little odd to me (not that I've seen any before). Can someone more experienced help me with understanding these readings?
Phil
Idle
At 1500rpm
Phil
Fishyboy (11-06-2019)
Received 1,702 Likes
just an FYI:
when collecting data above idle speed, the engine needs to be under a load, moving down the road. Preferably going up a slight incline. Not just revving in Park or Neutral. Revving the engine without a load tells you nothing.
This applies to all ICE's, no matter whether they are fuel injected or carburetor fed.
Z
Z
You should be looking at the LTFT not stft when doing this test...
And they look good..... Bank 1 slightly high but nothing to worry about...
A smoke test may be in order to locate the small leak/leak's affecting Bank 1...
Last edited by XKR-DAY; 11-05-2019 at 10:21 PM. Reason: not reading original post correctly.
Dozens or hundreds of people across the forums on here have found the opposite.
Z
PS. : At an identical rpm, the trim numbers change dramatically when the engine is under a load vs, “free-revvjng” in neutral or park. Obviously, the gas consumption under a load is going to tell a much more complete story during problem diagnosis. This is methodology taught in every factory seminar I’ve ever attended, from 1970 onward.
I justify it by direct observation during 50 + years In the transportation service industry.
Z
Z
i stand 100% by my posts. Yes, an air leak can be detected without driving a car. However, there are a multitude of fuel trim issues, including air leaks, which can be intermittent , which are best revealed by driving a car and examining the data stream log from an engine under a load. Don’t take my word for it, the SAE guidelines for trouble-shooting will say the same thing.
But what do they know ? Why rely on experience when there’s Google ?
Z
I'll take a moment to rely on experience. :-)
2002 xkr
My long-term fuel trims are both high negative, averaging somewhere between - 17 and - 20%. and are equal on both banks.
They occasionally trigger p0172 and 175.
I also get code p1111 which I believe is pointing to the IAT sensor in the MAF.
If the intake air temperature is reading a false high, am I right in assuming that that the ECM will think the air density was correspondingly low and that the fuel needed to be reduced to compensate?
2002 xkr
“......2002 xkr
My long-term fuel trims are both high negative, averaging somewhere between - 17 and - 20%. ,and are equal on been banks.
The XKR MAF is much pricier than the XK8 version, so I was not especially anxious to replace it. It took 3 separate cleanings before the cleaning was effective enough to solve the issue. I admit, before the 3rd cleaning, I was about to give up and buy the new part.
So even though the MAF may look pristine, another round of spray cleaning may be in order.
additionally, with the engine running, try wiggling the MAF
connector. If the idle speed / quality changes, then a little adjustment of the connection is in order. Worked for me.
Z
your attitude is learning me a lot more than just fuel trims. Disrespectful posts regarding my knowledge and experience are more telling about you than they are about me..
Z
Z
As I pointed out, that is wrong.
BTW no need to resort to insults even if you can't bear being corrected.
jagstuart
09-24-2017 05:02 PM
