HELP: Octopus hose Norma connector question
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1299/octopus_hose_norma_connector_0deb0291a596b957d286b39dfb4b8709054c2f08.jpg)
Octopus hose - inlet side
Attention All XK8 old hands:
I'm replacing the Octopus hose. A metal pipe from the engine sends hot water to the heater by mating with an enormous Norma connector (metal pipe on the left; black plastic part with a green ring on the right the Norma).
My question is how do you lock the pipe on the Norma? After inserting the pipe into the Norma up to the white marking on the pipe, how do I "lock up" the pipe securely in the Norma without any leaks?
Your early advice would be greatly appreciated.
Received 2,381 Likes
I recall a collar that slides forward towards the metal pipe once the connector is in place (after the green ring is removed) like this:
https://www.jaguarforums.com/forum/x...83/#post815336
There should be a raised ring formed in the metal pipe that the tangs on the connector 'hook' over:- but I don't see one in your pic? It's clear in the first post in GordoGatCar's thread above.
Pristine97XK8Convertible (03-17-2019)
Thank you Gents for your replies.
After reading up this subject all over this forum, I have to conclude that the heater pipe NCA3905BB which I ordered from SNG Barratt UK is defective because it did not have a ridge to allow the Norma to grip tightly.
I have to resort to just inserting the Norma into the pipe as far as possible and then applying a large amount of heat-resistant cement around the joint to hold the Norma in place. Will let the cement dry overnight before firing her up to find if there is a leak. Wish me luck.
You may have a very good point because I've read so many posts asking how to free that Norma when replacing the Octopus hose. Dispensing with the ridge on the pipe will surely allow easier Norma disengagement.
martinrichard
02-20-2023 08:43 AM
