Help!! Parking brake is stuck on! - RESOLVED
99 XK8, was cleaning out a leaf or 2 just now lifted the brake to get something under it AND IT WON'T Release! Is there a trick? Where do I start, had to limp it 2 blocks back to my office at 2 MPH, hoping I wasn't destroying anything or going to catch the backs on fire. HELP!
The following 5 users liked this post by WhiteXKR:
Babyaardvark (08-01-2017),
Greenbrook (06-07-2011),
IXLLER8 (06-14-2017),
joepanels (08-28-2017),
OA5599 (11-18-2017)
Don't feel bad, on the first morning after I bought my XKR, I could not get that dang e-brake unlocked and was afraid of burning the rears, so I had it towed into my mechanic, who called me and said, "What's the problem, it works perfectly!" I would swear on a stack of Bibles that I tried every combination of pulling up, letting down with pressing the button, without the button, etc. possible, but it's never happened since, so it must've been that idiot known as me. I'm sure it's happened to a lot more owners than care to admit it.
After spending many K's getting my new XK8 road worthy, chain tentioners +, I couldn't get the cruise control to work. From past experience with other brands service dept's I was sure the Tech broke something. When I called the service writer I'm sure he could hear the anger in my voice. I wanted a new appointment. He said "look below the shift lever does the button that looks like a clock have the little red light on?" We've been friends since. Jack
Not to feel bad at all. The parking brake on these cars is a lot like a vestigial organ: odd, quirky and sometimes painful. The day I purchased my 2005 XKR a fiddled with the parking brake for about fifteen minutes before a caught onto holding in the button. Just hard to believe that Jaguar would consider such an outdated system.
The handbrake allows you to do stuff like this.
YouTube - Ken Block and 530 whp Subaru Impreza WRX STI
OK, the fact that that car has 530 hp and weighs 1000 pounds less also helps. But still, without the handbrake some of those moves wouldn't be possible. I've seen another version of that video where they show a view from inside the car, and he's using the handbrake quite liberally.
I think they call it a "fly off" handbrake. The British used to, and maybe still do, have a auto event called "trials". It's sort of like an off road rally. In trials you use the handbrake a lot and this system they found the most efficient. As a result, it has found it's way onto lots of British "sporting" autos.
B
![Talking](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
Thanks to those above for the "quick fix". Use it regularly, but this time pulled a bit harder & my normal release didn't cut it.
With other lighter & sorta more playful vehicles, especially in the snow, you can temporarily with black electrical tape, tape down the release button so the handbrake does not latch-up when pulled.
Great for drifting...
Also in Canada and likely the northern US, where snow/salt corrodes stuff quick, NEVER, and I mean NEVER get into someone else's car that is a not brand spanking new and set the "foot" type parking brake. These horrid devices common to many US made vehicles is destined to SIEZE ON immediately after being depressed, never to be released again untill cut away. The only thing more frustrating is the owner's responce "..why would you ever use that??" Just generations of automatic transmissions and poor driving habits. Funnier than hell though when it doesn't involve you.![](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
TheCounty
![Icon Twisted](https://www.jaguarforums.com/forum/images/smilies/icon_twisted.gif)
TheCounty
The first day I got my XJ-S convertible, I put the top down and up with no problem. Next morning the top would not work. Panicking, I started checking the pump, looking up the fuse number, fooling with the switch. Finally, I checked the manual and found the parking brake had to be engaged for the top to operate. BTW, while opening the trunk to check the pump I managed to break the antenna, which I had not yet learned automatically retracted when the trunk lid was raised in order to clear the rear deck spoiler. Not knowing spoiler would hit the mast, I didn't realize you had to wait a few seconds for the antenna to go down. Had the car less than 48 hours and already broke something!
