Help Please!! XKR keeps unlocking itself
Often times a dying battery causes these cars to do strange and illogical things. In September 2012, my wife's XK8 popped the trunk lock open several times all by itself. Turned out the car's battery was failing. A new battery solved the issue. These cars consume massive amounts of power and must have a strong battery at all times or strange things happen and spurious trouble codes get thrown....
Gerard (07-15-2014)
Steve
Have you ruled out the possibility of the Unlock Button on the Remote becoming hiper-sensitive on its way to failing? The remote will work from a good distance. Check if removing the battery from the remote will require reprogramming, which is easy to do but be sure you have the instructions. Switch to the other remote and remove the battery from the one you normally use and see if it stops occurring. And be sure your teenage kid isn't playing tricks on you!
