Help, replaced battery, car won't unlock, just beeps - Resolved
Hello. My 1998 xk8 sat for about 2 months. I charged the battery, then when I try to unlock the car, it's just beeps once and nothing happens. I replaced the battery and the same thing happens, just a beep. Please help.
Check drivers side fuse #5, #15 and passenger side fuse #15.
If the fuses are OK, start the car, reset the windows (roll windows down, keep holding buttons until you hear a click then roll up, keep holding buttons until you hear a click) shut the car off, and try it again.
If it still does not work, try the battery disconnect-reconnect, start the car, window reset routine a few times.
Assuming you have a convertible, my suggestion would be to follow the instructions in this thread: https://www.jaguarforums.com/forum/x...-closed-71304/ to open the rear quarter windows from the trunk by bypassing the relays.
Then reach in with a coat hanger (unless you have very long arms) and try to unlatch one of the doors from the inside.
Did you charge the battery when it was connected to the car?
What sort of charger did you use?
Do a proper hard reset
https://www.jaguarforums.com/forum/x...connect-74146/
If that doesn't fix it we'll need to look at a possible fried module somewhere.
