help with restricted performance issue
Old 10-28-2014 | 08:36 AM
xk8lattmaster's Avatar
Got a code of p1262, engine light is still on but Restricted Performance light is off
Runs good, except when the Restricted Performance light comes on.
Old 10-28-2014 | 09:15 AM
johns427's Avatar
Bad coil, cyl. no. 2
Old 10-28-2014 | 09:23 AM
johns427's Avatar
Oops, thats 1362, There is no 1262. Are you sure it's not 1226 instead? I hate it when you go to all that trouble, and the code is not listed!
Old 10-29-2014 | 08:33 AM
I'll check it again tonite and get the right codes
I thought it was P1262, but I may have been mistaken, but that's not likely
Old 10-29-2014 | 11:20 AM
johns427's Avatar
I googled p1262 for Jaguar and it stated "cyl No. 2 high to low side short" It could mean faulty fuel injector, loose or dirty fuel injector connection, or shorted fuel injector. I would first check to see if it's actually connected and then clean the contacts.
xk8lattmaster (10-30-2014)
Old 10-29-2014 | 08:02 PM
Gus's Avatar
Gus
Make sure that code number is correct unless you want to keep guessing and if it is P or C.
Old 10-30-2014 | 08:26 AM
Cool P1262
Thanks John,
don't know why they thought it wasn't a good code.
  #28
Old 11-14-2014 | 09:44 PM
bhunter417's Avatar
The code man! The code! (Seinfeld reference )
I am having the same problem but mine is an XKR. Mechanic said it is more rare for the super charger but that was just over the phone. Guess I will leave it with him since I wouldnt have a clue how to check/clean, etc anything in that engine.
Old 11-14-2014 | 10:05 PM
chopr's Avatar
(Oops. I posted this before reading that you DID get a code. Well, the info may help you anyway. Another direction to look.)
Without having a code to give us a place to start, it is just a crap shoot. The port is easy to see under the dash. I have had a P0171 (lean) code, and restricted performance light happen. The MAF was reading incorrectly. I also have this situation which may be contributing to the overall issue: In my situation, the intake seals need to be replaced; pretty common on a high miler. (runs a tiny bit rough on cold start, enough to cause misfire codes once in awhile). The MAF needed cleaning. The books will tell you not to clean the sensor. BS. Spray the sensor window with some carb spray, and give it a try. Worst case scenario is buy a new MAF. This is all great.... IF.... your code is a P0171!
  #30
Old 04-15-2015 | 10:47 AM
chas_c's Avatar
Default P0301 and P0201 Restricted Performance
I am having a similar problem since I changed my Spark Plugs.
I have swapped coil packs 1 and 3 but still same codes (pointing to Cylinder 1). I was hoping the code woudl change to coil pack 3
I added Sea Foam injector Cleaner and for a few days it was okay but I have RP again and rough idle when cold.
When restarting the engine when normal running temp, everything is okay
Any ideas
I cant remember my signature so:
2004 XK8
93,700 miles
4.2 litre engine
  #31
Old 04-15-2015 | 11:45 AM
Gus's Avatar
Gus
I would now swap the plug and see what takes place. I should mention that you should look at the plug to see if it is damaged when you pull it.
Any ideas
2004 XK8
93,700 miles
4.2 litre engine
D.K
12-10-2023 03:05 AM
PMKimpton
08-03-2019 09:22 PM
Aus V8S
11-13-2015 12:01 PM
scottatl
09-04-2015 09:08 PM
XFR_Gold
09-02-2015 01:24 PM
Quick Reply: help with restricted performance issue
