Help!! space between the hood & front bumper
Guest
Posts: n/a
Body Clearances and Alignments on XK8s
Hey MRMAGNUM, congrads on your 1st XK8. You didn't mention MY in your post so what I'm sending may not be much help. The Jaguar JTIS Workshop Manual I have covers MY 97-04 XKs. I have an 02, so I zipped the pages from the CD regarding the body alignments and clearances. I highly recommend you pick up a copy of the JTIS. Got mine on eBay for less than $20. I'm also new to this site and don't think I can attach the file to my reply. If you send me your email address I'll reply back with the attachment. Its 6.80 MB.
Good Luck
Good Luck
JTIS is available as a free down load on this forum:
https://www.jaguarforums.com/forum/s...ead.php?t=9933
My clearance is about a 1/4".
Welcome aboard!
Welcome aboard!
Hi XK8INMD! super thanks for your quick reply & for the info!
my email ad is williamjessemagnum@yahoo.com
Glad to be here! Thanks again!
Gordocatcar, i added 2 photos from a link thru my flickr photos page on my first post above but it didnt show up.. anyway, here's the link.
http://www.flickr.com/photos/1105582...26216/sizes/o/
the gap is around 0.4-0.5cm wide
That is definitely a large gap. The front fascia can be raised a little by the use of shim washers under the front edge of the fascia. Keep in mind there needs to be some gap in order to allow the front edge of the hood to dip while raising the hood.
If you look on your JTIS, you'll also note there are three (3) bolts on each side attaching the fascia to the lower fender edge. You may loosen these to facilitate a better fit.
I would be cautious about religning the hood on its hinges because of issues with the locking mechanisms at each upper hood corner.
Pulling the front fascia is not a difficult task. You can access the front bolts and three (3) push pins by raising the hood to its "service position" which is nearly 90 degrees vertical. Do this by removing the support pistons and inserting one each bolt on either side of the front hinge location. It looks precarious, but is actuall quite stable if you are not outdoors [in the wind].
MC36
US Lower Atlantic
09-01-2015 07:34 PM
