Hey, Rear End Noise is Gone
Thanks for all the help guys. Motor was correct about the E-Brake being the culprit. Thanks to H20 for the procedure. Got a few minutes and adjusted it today. I was going to wait for the parts for the rear suspension to show up but got impatient.
So if any on you start hearing noise from the rear wheel wells that's sounds tingy. Time to adjust the e-brake.
Sounds about right george, I compare it to the sound of old spoke rims.
Not a total victory yet H20, I need to replace the drivers side e-brake shoes cause I rotated that little gear till it couldn't rotate any more but still wouldn't lock drivers side.
Passengener locked and handle actually had clicks so I call it a small victory. Noise is gone except for hefty bumps but much less pronouced.
I deal with the shoes when the noise gets loud again.
Quick question for you; on the drivers side there was no plug so adjustment was easy, just lined up the hole. Passenger side had same hole but smaller diameter was solid, no through hole, and now way to pull it out.
So I guess the question is, was yours like this?
The passenger side didn't seem to need adjustment so I didn't worry about it. But I guess to open that hole up I need to remove the Disc.
