HID Ballast, how easy to change?
There's three sections in JTIS covering the Ballast change procedure with HID's:
JTIS - XK8 Headlamp Assembly.pdf
JTIS - XK8 HID Ballast.pdf
JTIS - XK8 HID Headlamp Adjustment.pdf
I have done adjustment and you may find the adjuster is worn and doesn't click into place for adjustment. However, a bit movement will get the position where adjustment can be made.
malbec (04-14-2013)
rsa760041
23
09-25-2015 01:33 PM
