HID headlights switch RH to LH dip
Hello
There was an earlier post on this
https://www.jaguarforums.com/forum/x...itch-eu-64196/
with a picture of an Audi headlight but the thread sort of petered out without an explanation of what actually has to be done.
I'd be most grateful for an idiot's guide since I'm probably going to have to try doing this in a hotel car park!
Hey Steve;
I think the answer depends on what year your car is.
These posts from my earlier thread are in reference to the mounting brackets on the back of the lights.
Originally Posted by Frog
I don't think you can: the RHD deflectors are a completely different shape.
Jamjax, here is a link to the eBay ad where I found my deflectors. I have bought bits from the seller (a Jaguar breaker) before and they're pretty good. I will need to fit the deflectors before the car's next contrôle technique, but that's not until January 2013.
Originally Posted by avos
Yes you can turn them arround for HIDs (which JJ has). The ones you show are for the halogeen headlights, and these indeed can't be turned (although with some mods you can).
So you depending on the year and type of lights you have, you can either just turn them around, switch them from side to side or buy LHD brackets to remount them.
And I repeat my earlier un-answered question to the forum :
Is there a way to adjust the cutoff height of self adjusting HID head lights?
good luck and let us know what year and model you have.
cheers,
jj
cheers,
jj
It is a simple job, only a lot of work iirc. The headlight needs to be removed which will be the hardest part. Then you need to take out the inner light mechinism and you will see for yourself the deflector plate (which sits between the lens and the light), all you need to do is turn the deflector arround.
The following 2 users liked this post by avos:
jamjax (12-30-2011),
steveinfrance (12-30-2011)
Thanks Avos....as usual.
Steve you can edit your Avatar and your signature after ten posts I think...and then the info will be displayed....
Seems we have the same car.
What color did you fall in love with?
Never heard flophead droopy before, fun.
They say you don't learn more French you forget more English the longer you are over here.
cheers,
jj
cheers,
jj
Jamjax
I do believe 'flophead droopy' was actually coined to describe the XK120 drophead coupé's real life appearance!
I've gone for slate grey with ivory leather - I couldn't find one in BRG.
Point well taken about black leather in another post BTW, when your flophead is drooped there'd be serious risk to the nether regions in summer here.
Our closest friends live just outside Geneva BTW. He is a Swiss accountant so they can afford to spend 6 months there and 6 months here in the Limousin!
Steve;
My grandfather had a grey with red interior XK120 Coupe....very classy looking but therefore I never got the 'dope' on the name or the convertible.
That is actually the color I was looking for and couldn't find, this is my second choice but we really are enjoying it.
Come on up for some skiing and fondue or raclette this year.
Give us a shout if you are in town.
Not in the XKR presumably.
cheers,
jj
cheers,
jj
Sorry, it's the engineer in me speaking. The vertical axis is what you'd get by holding a plumb line across the centre of the thing so rotating it round that is, as you say, rotating it horizontally. Beam me up vertically Scotty!
HID conversion RHD to LHD
Hello all
I bought a pair of RHD HIDs with the intention to install them in my 1999 XKR. The wiring is OK but I need to convert from RHD to LHD as I live in Sweden. Before taking the light out, I studied the mechanism and noticed that there seems to be some sort of mechanism that lockc the direction of the beam in a fixed direction between left and right.
Anyway, now I have the HID out and am looking for the plate that needs to be turned by 180 degrees. Between the bulb and the lens, there is fixed plate that pretty well covers the lower half of the reflector. There is a V shaped bulge which points towards the lens on the upper side of the plate on the one side.
--> Is this the plate that needs to be turned?
--> Or is it simply that I should use the 'left/right' adjustment mentioned above?
I have a photo if I can figure out how to attech it (new member!!).
Mark
Mark
WTB[NorthEast]: 2004 Vanden Plas Headlight Assembly LH
European_Auto11558
09-25-2015 08:05 PM
1964Daimler
09-09-2015 11:28 AM
