HID kit install in pre-hid vehicle
newheart8 here. have installed the 35 watt set with 5000 bulb temp and they are the whitest
white light. no problem with car sensing 35 watt. The 6000 bulbs start to look blueish which
is a give away. Good Looking
I have fitted many 35w kits without a problem, all early XKs did not have a headlight bulb out warning system (not in the UK anyway), I should imagine they assumed if you couldnt see you had a light out you shouldn't be driving. ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
No point going mad with the brightness as techniquely as of sometime 2012 they are not legal in the UK
I have fitted an HID kit to my 99 XK8, I thought they were only legal in the uk with auto height adjustment and washers anyway. So whats changing in 2012?
regards
Thats correct, for them to be legal you need auto levelling and washers, it is a bit of a grey area but at this moment in time it is OK to fit them by an individual but not by a company (so I am told) however they will be an MOT failure as of next year if you do not have all the necessary requirements.
The main reason is because a lot of boy racers in there Saxos and Corsas are fitting them to standard light units and not the projector type as fitted to most modern vehicles including XKs.
smoggyx100 (10-20-2011)
Re. MOT's in the Uk and retro-fit HID's.
They will NOT be an automatic fail after April 2012, what you will get is an advisory stating that "the vehicle has HID headlights but there does not appear to be an automatic headlamp levelling system installed". Vehicles built from 2012 onwards will fail if a fitted headlamp wash system isn't operating, also if factory fitted TPMS isn't working correctly. Airbag lights are also included at the same time, as is the visual inspection for presence of a catalytic converter if it left the factory with one.
The intended regulation changes would have outlawed aftermarket-installed HID's on vehicles with no headlamp wash and no height control, but as usual the legislation was watered down!
Non-canbus H1 with slim ballasts and 4300K, and they should fit with minimal hassle?
#30
The hardest job is removing your headlights, but fit them insides the light unit it looks more professional than having them rattling around outside. You will find you have to remove the dip beam reflector to get the wires through, easy enough to do like I said with the headlamp removed!!
#31
#32
I just installed 35 Watt HID lights in my 2004 XK8 last week. I put them in the low beam and the fog lights. The fog lights was a jury rig not, really made for them, and I actually don't see any improvement with them, would not do it again. The Low Beams however are a vast improvement and were a direct fit. Highly recommend that upgrade.
#33
#34
trosty
26
12-18-2022 06:40 PM
rsa760041
23
09-25-2015 01:33 PM
