High flow cats
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
Lossking, Eurotoys in Chicago has a real nice set for $1,299.00. That's just for the Cats, then you have to put them on! What I did instead is to buy a couple little 2 1/2" 200 Cell Magnaflow Cats and had a Hot Rod Shop here in Houston build me a set that hook-up to my Quicksilver Exhaust-System.....I found a wrecked XJR, whose Manifolds are more streamlined than the XKR's, as they exit at the rear in a 45 degree angle instead of a 90 as the XKR manifold. They have a Ball joint connection instead of a Flange, which makes them more maneuverable. Then run them down to your exhaust pipes and hook them up....Of course you have to weld in the Oxygen Sensors connections before and after the Cats. All of that will probably cost about what Eurotoys charges just for the Cats....What would be better? A good set of Headers made just for the XKR!......I found a guy in England that makes and sells them but they go for about $2500 Bucks US...Considering he is the only one around making them, I guess you would say, "He's got the only deal in town"! Only one I've found anyway......Sure wish someone here in the USA made a set.....Anyway, you can do it! It only cost Money!
Billy Clyde in Houston
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Lossking,
You must get under the Car......Look where the Cats come down and connect to your exhaust system......Does the pipe slip over the exhaust pipe or does it butt-up to and bolt-up to a flange. That is what he wants to know.....but as I said, for about the same money you can make your own....Just find a Muffler Shop or a Hot Rod Shop and let them have a go at it......As grandtorino62 sez "It may not get you any more Torque but it will get you on down the road"!
It's a picture I got from Google, but I would love to do this to my car as well. You can pick up some serious power with just some bolt ons. And it's a LS engine, so it'll last forever! Even stock, these come with 430 horsepower without any mods whatsoever. Now imagine doing some headers, exhaust, throttle body, a cam, manifold, and a tune ... easily put you over 500+. I love my car but there's not too many mods for them. I want to keep mine forever, even if I'm hated by the Jag Community for swapping engines LOL
