High revs on cold start.
zray (12-30-2022)
Received 1,701 Likes
When you disconnect the battery, the first time you start the engine WILL REV to 2000 RPM!!!!!!!!!!!!! (normal)
Sometimes you can get the engine to stop this behavior by turning the key to ON/ENGINE OFF, then depress the throttle pedal several times, turn the key OFF.
Start the engine and see if it helps?
JimmyL (02-08-2023)
High Revs
Another issue has raised it's head. When the car is started from cold the revs are higher than normal(too high) and take a while to settle down, once it has settled it can be started and all is well. Any thoughts on this latest issue are much appreciated. Many thanks again. Anthony. Happy new year to you all.
I have a 2014 3.0 XF and it just started doing the same thing. With a cold start (Usually when it is colder than -25C it over revs to the governed limit, warmer and it tops off at 2800 rpm for a minute or so then drops down to normal idle), The car throws 2 codes, P2189 and P2187. It has been to the dealership a few times and apparently there has been some sort of TSB for the O2 sensors so I'm just waiting for them to come in and they will swap without charge.
I have had the same issue with the 2010 XF 5.0 to a lesser degree when the MAF sensors required cleaning and the COV sticking open for a bit,
Hope you had it fixed by now but if your still scratching your head, here was my two cents.
Kevin
We are starting to see more vehicles coming to Canada without winter packages which is strange, these cars are ordered with the winter packages which include the heated windscreen, electric pre-heat, heated seats and steering and the block heater and normally these vehicles are great in winter with the AWD and the heavy weight. The only addition I add is the electric battery blanket to keep the battery warm as a frozen battery is not a good thing. Finding a place to plug in is the real issue when your away from home.
The high revs is not normal even in our conditions.
ozbot (02-10-2023)
#30
For the Canadian prairies, -25 deg C is very common for at least a quarter of the year. Our temperatures range from +35 to - 43 deg C with changes in excess of 30 deg in a day at times.
We are starting to see more vehicles coming to Canada without winter packages which is strange, these cars are ordered with the winter packages which include the heated windscreen, electric pre-heat, heated seats and steering and the block heater and normally these vehicles are great in winter with the AWD and the heavy weight…..”
with -22 C (-8 F) not uncommon. Although it doesn’t last for months, just days or a week or two. AFAIK, no cars for our market are
fitted with any special winterizing features.
Summers are the worse here. Always have a few weeks of 41 C to 45 C (106 F to 113 F)
Plants and livestock suffer the most. Vehicles and people next in line
Z
#31
out here on the Oklahoma plains our temp extremes are nearly as bad in the winter,
Z
Z
#32
Kevin
Kevin
JagV8 (02-13-2023)
#33
KeremArsan
05-09-2018 11:56 AM
