High RPM
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Hello all;
I have high idle RPM (1250-1500) on my XK8 2002 that will not go down! I checked air leaks, changed the throttle body, and re-sealed the TB Gasket, no use.
I get errors related to O2 sensors (all 4 appear to be out) (P0031 P0037, P0051, P0057, P1646). also I get P0010 and P0020 related to VVT circuit malfunction (solenoid related malfunciton). I also get P0507 "Idle higher than expected"![Icon Denk](https://www.jaguarforums.com/forum/images/smilies/icon_denk.gif)
Could any of these be responsible for High RPM? or should I keep chasing air-leak ghosts?
MJ
MJ
MJ
Another good guess..
After fitting the re-manufactured TB (ASI), I took the battery off, shorted the car + and Earth cables for 10 min, then fitted the battery back. After that, according to ASI instructions, I held the switch to the on position for 60 sec before firing up.
I must have done all of this at least 5 times, no difference...
I take it you don't believe O2 sensors could be a cause, no?
It wan't easy.. but I finally got the RPM down, and with a little bit of help from ASI who supplied the rebuilt TB, and a lot of help from Shots in the Dark Inc.
The ckeck list pre-resolution (didn't work but may be useful reading):
1- Reset sensors (disconnect + and – battery cables, short them for 5 min using jump leads, reconnect, place switch to the on position before ignition for at least 1 min, hit ignition)
2- Clean mass air sensor with non-residue electrical spray (I saw a good technical note on this at the "how to" thread)
3- Checked for cracks in air pipe, the ribbed part becomes brittle with time. I did have a small hole and I'll submit a separate thread on a useful product I found that helped with this.
4- The air pipe has a habit of slipping off at the mass air sensor pipe leaving a decent gap for an air leak
5- The air pipe is nice and snug onto the throttle body, I wedged cardboard between the gasket and air tube to push it into a tighter seal with the TB
6- MAS base air leaks could also happen
7- JITS says to also check part and full breather hose connections for leaks
8- It is possible though unlikely that the TB base gasket is leaking (the one between the TB and the elbow), I added a thin layer of gasket silicon to both sides of the TB gasket to ensure tight closure. the down side is that last I checked I could not remove the TB from the elbow! I topped trying and could not recommended this
9- Reset TB sensors again after all possible leaks eliminated
10- I saw another good technical note on the "how to" thread to ensure that all the wires connections are making good contacts.
No use
![Icon Poop](https://www.jaguarforums.com/forum/images/smilies/icon_poop.gif)
OK, now for what actually worked:
ASI says that when all else fails, adjust the position of the TB sensor by undoing the two bolts holding it in place just enough to nudge sensor; the holes in the sensor assembly that the bolts go through have a lot of space for adjustment.
I looked into the bolts and they looked like torx 20. But a closer look revealed something altogether more sinister, a pentagonal star!
I spent the next week looking for a bit that would fit into them darn bolts (I think called pentalobe or something just as silly), and finally found a full set for ~25 USD. I think I used the size 20.
Armed with tools, and while lovingly and repeatedly burning my knuckles on the TB and engine, I managed to undo the bolts a little. Nothing happened. I nudged a bit, nothing happened. I nudged a bit more, the sensor jumped about 2 mm all the way back (towards the rear of the car) and the engine stalled. Brown pants moment![Icon Errrr](https://www.jaguarforums.com/forum/images/smilies/icon_errrr.gif)
I moved the sensor back to where I thought it was before (or maybe .5 mm towards the rear of the car) and tightened the screws again. The car started fine but the RPM stayed the same at ~1200-1500.
As I was contemplating giving up, I reset the sensors one last time by removing the battery like I mentioned before.
Started the engine
RPM 600-650 for the first time in a month.
Basically, yay![Icon Banana](https://www.jaguarforums.com/forum/images/smilies/icon_banana.gif)
Been driving for a couple of weeks now, no problem.
And that, ladies and gentlemen, is the sweetest shot in the dark… Thank you SitD Inc.
No use
Started the engine
Basically, yay
