hit bump..lights out :(
Old 10-17-2015, 09:28 PM
markb721's Avatar
Default hit bump..lights out :(
Hello, I am new but I am hoping someone can help. Driving home tonight got a bit scary while driving through a construction zone. Every time we hit a decent size bump the headlights and all interior lights flashed off. Fortunately they just blinked off and came back but it happened four times. I was wetting my shorts waiting for things to go lights out permanently. Has anyone experienced this before? Any clue where to start looking?
2003 XKR 4.2 L SC
Old 10-17-2015, 09:53 PM
WhiteXKR's Avatar
Received 2,988 Likes on 2,125 Posts
Make sure the battery cables are tight, and re-squeeze the crimps with a large pair of pliers.
At the back of the trunk are two master fuses...make sure these connections have not loosened.
There is also a heavy wire master power connection at each fusebox. Make sure these have not loosened either.
For safety, disconnect the battery before touching a tool to any 12v connections to prevent accidental shorts that could burn you.
Old 10-17-2015, 10:04 PM
markb721's Avatar
Thank You, I will start there in the morning. I love your website by the way and will be purchasing your kit to make my temp and oil pressure gauges real. I hate things that appear to be something they are not, so I will be rectifying the gauges in my car soon.
Appreciate your time, Mark
WhiteXKR (10-17-2015)
GIJoe
08-17-2021 10:00 AM
svirk2
10-08-2015 05:44 PM
hughey
10-02-2015 05:17 AM
kevinl
09-24-2015 08:25 PM
Quick Reply: hit bump..lights out :(
