Hitch on the XK8
Old 08-30-2012, 02:21 PM
mp5802's Avatar
Default Good job.
Nice.
So, you had to cut a notch or hole in the bumper?
- Mike
Old 03-24-2013, 04:32 PM
Savage's Avatar
Thumbs up Ok guys I'm ready for the attack!
1946 Classic Gar Wood Runabout $
2006 Jaguar XK8 Loaded $
Being able to enjoy the ride and the boat show....... Priceless!
Norri (03-25-2013)
Old 03-24-2013, 04:50 PM
Kevin D's Avatar
The only thing that I would say, as I suspect that you know, is that I would recommend that at highway speeds, I would not put it into overdrive.
I think that you have a six speed in a 2006. I'd recommend that you go no higher than 5th gear.
I am no Jag transmission expert, as some on this forum actually are, but I do know that in my other vehicles when towing my boat, after blowing up two transmissions by towing in overdrive, I was told that the overdrive gear in a car is not designed to take the stress involved with towing a boat.
I am not sure, but I suspect that the same would be true for your Jag transmission.
Old 03-25-2013, 06:22 AM
Cat888's Avatar
Priceless! LLOLL...
Old 03-25-2013, 06:54 AM
Frog's Avatar
Only in America would you see a combination like that ^. I love it
Old 03-25-2013, 07:32 AM
Received 6,320 Likes on 5,507 Posts
How does it cope on the launching ramp?
Old 03-25-2013, 06:54 PM
Savage's Avatar
Default No launch
This is for the ride there only. Car is MUCH to low to launch on most ramps and I would think you would have to get water in the trunk before the boat would float. My buds from the boat shows launch for me. I have only taken it for short runs but am going to the Apalachicola Boat and Classic car show in April about a 4+ hour trip. Wish me luck!
Norri (03-25-2013)
  #28
Old 03-25-2013, 07:03 PM
Bon Voyage!
Old 03-26-2013, 04:51 AM
Received 1,231 Likes on 716 Posts
Very nice, Savage.
Good luck, but we will expect some decent pictures as well.
  #30
Old 04-21-2013, 02:32 PM
Savage's Avatar
Default Tow was FANTASTIC!
Mileage: 245 mi (One Way)
Time: 4 hours 40 min
Gas Mileage:This shocked me, I expected less- 20 MPG
The transmission guide from ZF said that the "transmission controller (computer)would sense the towing load and adjust the shift points accordingly" and while reading this I thought "yea". Well blow me down this thing shifted wonderfully and did not hunt at all! The guide did not say to not tow in overdrive but I did not feel comfortable doing that and left it off.
Man this thing blew my mind with how well it did.
Absolutely gorgeous drive with the top down-Fabulous weather and the boat won "Best of Show- Restored"
Pictures will follow
IT JUST DON'T GET MUCH BETTER THAN THIS!
  #31
Old 04-21-2013, 03:05 PM
Kevin D's Avatar
Congratulations all around.
If they had had a category for boat/tow vehicle, you would have, no doubt, won that too!
And, BTW, that is amazing mpg, especially in 5th gear. I think that was a smart decision not to tow it in 6th.
  #32
Old 04-21-2013, 04:39 PM
Congratulations!
  #33
Old 05-25-2014, 11:30 AM
franksm's Avatar
Hi lads
I am blown away by Savage's photo of the XK8 + Gar Wood combo. Ridiculously fantastic.
I had a nice bike-rack setup on my now-retired MX5, and want to do the same with my XK8 coupe. Looks like the Curt product will fit the bill !
One question, though: does the rear bumper need removed to do the drilling ? Or can it all be done from underneath ?
Attached Thumbnails Hitch on the XK8-wales241430_10150176679823509_5013121_o.jpg
  #34
Old 05-25-2014, 03:46 PM
TreVoRTasmin's Avatar
Originally Posted by franksm
Hi lads
You should be able to print directions for the install via Curt's website. I know on the XJR x308 everything was done underneath.
  #35
Old 05-26-2014, 04:21 PM
Savage's Avatar
I had no problem installing without removing the bumper. I used a Dremel tool and cut to the center of the hitch where it hit the bumper and worked my way out until it fit nicely. If you do not notch the bottom it does require you reach under the bumper to attach the chain if you need them. If your not towing , bike rack, basket, etc. it does not matter.
franksm (05-26-2014)
  #36
Old 05-26-2014, 04:23 PM
Savage's Avatar
I will try and get closer under the car shots in a few days.
  #37
Old 05-26-2014, 05:00 PM
franksm's Avatar
Thanks, appreciated. In the Curt diagram, it looks like the bolts are into the box section behind the bumper, and that's what needs drilled (bolt #2 in the pic)
My bumper has been Tigersealed into place in the wheel arches, as the brackets had disintegrated with rust. So, I want to avoid removing the bumper if possible. Awful story with rust on Irish and UK cars.
  #38
Old 05-27-2014, 06:56 AM
Savage's Avatar
Shame to hear about the rust, don't have much rust in my area..... not much ice salt on the roads in lower Alabama. Because I was towing a boat I did put a aluminum strip bar across the inside trunk and drilled through it. Felt it would give the bolts much more surface area for support and with a rust problem it might be something to consider in your case.
  #39
Old 05-27-2014, 07:29 AM
v8deuce's Avatar
Originally Posted by XKRacer
I have a strange urge to hire a hitman and send him to Canada!
LMAO
Randy
  #40
Old 06-12-2014, 04:26 PM
franksm's Avatar
Just in case anyone is thinking of ordering from Trends Auto - don't, you'll have your hands full with trying to get them to send anything after they take your money. Luckily the credit card company stepped in.
So I tried HitchAnything.com...
Two weeks later, money taken, nothing sent, lots of promises. I will let you know how it goes with them, but just take care if you are thinking of using them...
Quick Reply: Hitch on the XK8
