The "Hole" in the convertible headliner...
![Talking](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
I've been meaning to post this for a while.
I've seen numerous posts asking what that head liner hole is for. Well, I'm gonna tell you.
The latch hoses that go into the latch mechanism are the weak link in the convertible top system. The pressure required at that point is ridiculously high and the latch can barely handle it. That's why the top "hesitates" at the latch.
The "hole" in the headliner is a handle for you to put your hand and assist and therefore ease the required pressure at the latch for the closing of the top.
Put your hand in, and pull down the top to the latched position...it really is that simple...
![Icon Banana](https://www.jaguarforums.com/forum/images/smilies/icon_banana.gif)
If you are having difficulty with it not final latching you should make sure that the bypass valve on the pump has not rattled loose. It is a small tee shaped fitting at the base of the pump.
The latch normally should not need any assist. You might also get some spray lube and lubricate the latch they do get cruddy.
The small opening (round hole) is to use the hex tool (located on the side of the pump) and the oval opening (hand hole) when opening/closing the top in the Manual Mode.
A loose bypass will reduce the pressure to the system and create the latch problem.
It seems like there's some kind of contact in the bottom.
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1600x900/img_20240831_153225935_593946e3abdf5db09b9a6c0eec9be5f9b6d07a87.jpg)
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
