home link garage door opener
Does any know if all home link devices are the same. The 97 XK8 conv. that i bought last week is missing the homelink (it has been removed). I have the bessel and the rubber button strip, but there are no "guts". I would think that the guts from any similar looking homelink would work, but i am not sure.
Any help would be welcome.
Thanks in advance.
Thanks in advance.
Did a quick search for you in the XK8/R forums, found these...I think it will answer all your questions.
I'm not a homelink expert, nor do I play one on TV, but the homelink function in a Jag (or a Yugo) doesn't really need to be integrated into the car at all...
It gets power from the car, but just sits up there and transmits whatever signal it has been taught, when you push the button. There is really no need for any other interaction with your car.
Now, while that makes perfect sense, realize we're discussing a Jaguar here, so it probably has all sorts of inter-connections with the cars electronics that we've never considered, like whether the radio is too loud, or the top is down, or the rear "seat" is occupied...
Somebody with a current JTIS should be able to report those intricacies here...
My '97 XK8 convertible's HomeLink module would not work with my garage door opener and I contacted HomeLink support at Chamberlin Group.
I learned the module in the '97 does not work with rolling code Garage Door Openers. Here is the official response I received:
"Prior to 1997, all HomeLink equipped vehicles were not compatible with rolling code garage door openers system (rolling code is the type of opener you now have). Depending on the manufacture date, even some early 1998 vehicles with HomeLink may or may not be rolling code compatible.
To check and see if you have a rolling code compatible HomeLink, look at the LED indicator light by the 3 buttons.
**If you have an oval shaped Red indicator light, then this is a non-rolling
code compatible HomeLink (not compatible with your opener).
**If your indicator light is located inside an Icon of a House, then this is a rolling code compatible HomeLink.
**If the LED indicator is amber colored (Yellowish Gold), this also is a rolling code compatible HomeLink.
If you established that your vehicle is not compatible with rolling code, you can make it work by installing a Universal Receiver in the garage. This receiver when used with HomeLink will bypass the rolling code feature that your opener offers. Your original hand-held transmitters and wall switch button will still work the same way they normally do, nothing is changed there.
You can contact a local garage door opener dealer regarding the availability of this device (non-rolling code universal receiver kit) or feel free to call our HomeLink customer assistance center at 1-800-355-3515. Our hours are M-F 5am-6pm, Sat. 7am-5pm MST. The cost of our Universal Receiver is $68.90+ ship/tax. "
Hope this helps so that at least you don't replace it with an OEM '97 or '98 module.
The rolling code GDOs were introduced around 2000MY and after replacing alot of 1997 to 1999 for not programming to customer's rolling code receivers we were told to stop 'warranty replacement' of units if they lit the red transmit indicator. The customers were told to purchase the newer rolling code GDOs (overhead console) and they were about $800.00 if I remember correctly. The lucky ones had the overhead console replaced when the top latch hose failed under factory warranty and the unit was filled with conv top fluid.
bob gauff
bob gauff
At last! Value in having the top latch hose leak!
I bought my universal receiver from a garage door company for $25 but that was a number of years ago. eBay has one for $9.99 + $5 shipping at the moment.
http://cgi.ebay.com/ebaymotors/UNIVE...Q5fAccessories
The Home-Link from any of the Jaguar cars should work. You may have to fashion the proper connectors.
Once the Homelink (in the car) has successfully learned the code, The opener (in the garage) has to be set to learn mode per the opener manufacturers instructions.
You mean the red button in my case on the main unit???? Once I have set the car (97) to the hand held transmitter then what do I do??? Just press the learn button on the unit?
Press the learn button on the unit. I think you have about 30 sec to then push the button on your car that you programmed from your handheld unit. The opener (I have a Genie) should then catch the code coming from the car and "learn it". It might take more than one attempt. Park as close to your door opener as you can.
Sometimes they can be frustrating. Mine is the push the button on the garage door opener unit, then go to the car to program it too. It worked with my '98. But my fiance has an '03 Jeep that I tried to program one day and it just wouldn't work. I tried until I got frustrated and gave up. Then I gave it a try in a week or two, and it worked right off the bat. And I swear I didn't do anything different.
