Hood latch question on replacing
I've never had a convertible so can offer no help on this one.
However, as your question has had 218 Views but 0 Replies so far, I'm posting to bump it back to the top of the list.
I know there's plenty of convertible owners out there familiar with the latching mechanism. Surely there must be someone with experience or advice ......
Received 6,332 Likes
The HOOD (over the engine compartment)(Bonnet) latch on my 05 XK8 has never been a problem until the other day. It would open with very little pull on the hood release and close just by holding the hood about ten inches from closing, then releasing to let the weight of the hood (bonnet) snap it shut.
However, the day came, that after checking all the levels, I followed the same method, but this time only the passenger side latched. The drivers side sounded as if it had hit a stop or closed latch.
Thinking it had just malfunctioned, I released the latches and tried again, but with the same result. Now I was concerned. My beautiful car had a problem.
After much head scratching and examination, my conclusion was that the latch had not remained open after I raised the hood, or at least, in the ready position to accept the hold down loop which is on the hood itself. So after satisfying myself that the latch had moved and needed adjustment, I got out my trusted 1/4 tool kit and started the adjustment.
Well, after many tries and adjusting what there is to adjust (up and down), I finally found a spot that would allow the hood to latch on this side, however, the location I found caused that end to be a little high, but after many tries, that one place I found was the only location that worked. The end is still a little high.
I would ask for help, but see from the post on this subject, that no one has had any problems in this saga of "My hood (bonnet) latch adjustment mystery". If there is anyone hiding in the back ground that has experienced this adjusting problem, a post on the subject or a private email would be much appreciated.
Cheers.
Chuck
Cheers.
Chuck
