Hood Not Latching Warning - How to fix?
I got this warning message today while driving and it won't go away. Of course, the hood is closed and latched securely on both sides. Even opened and shut several times. Car turned off and back on. Still thinks it's not latched.
So, where is the sensor that's sending this message? I've searched the forum and couldn't find anything so I'm hoping someone knows how to fix this thing.
Judi in Alabama (04-24-2012)
Yep, those silly Brits have funny names for stuff. They need to learn to speak English! LOL!
Hood=convertible top. Bonnet=hood. Boot=trunk. I spent an hour fiddling with my "hood" before I finally realized I was fiddling with the wrong thing.
Like Westra said, try cycling it. If that doesn't work there are instructions in the owner's manual which explain how to latch the top. There's a microswitch up near the latch that probably isn't making good contact. If you can get the latch opened and then re-close it using the Allen key in the trunk then it will probably be fine. The same thing happened to mine.
This is the car's perverse way of telling you it is illogical to start the car while the key is being turned in the door and the top is partially open...which is what the remote top controller emulates.
Bonnet-Hood-Boot, Bonnet-Hood-Boot - keep repeating
A Rolls service manual is even more perplexing. I messed up some wiring mistaking the storage loom (as the one going to the memory module that stored seat settings) but instead the storage bin is British for center console.
Does every USA first time Jag Convertible owner go through this at some point?
I ran into this leaving the office one nice summer day when my '03 XKR didn't have 1,000 miles on it yet. It took me long enough to figure out the "bonnet" opened from the back and not the front.![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
I spent around 15 or 20 min in the parking lot before I decided there was no harm done and didn't figure out it was the convertible top latch until I closed it an hour or two later and found the message finally went away.
OK, for potential future owners, here is my take on this.
I had the "hood not latched" error with the top fully up. I had seen this before but it never lasted long. This time it would not go away, and the top would not operate at all. I took the hex wrench form between the rear seats and opened the top latches, which released the top from the windshield cowling. I followed the manual top reset procedure, except I could not get the toneau cover to budge - is was securely fastened, even though the hydraulic pump was bypassed/disengaged. I figured I was screwed, as I couldn't put the top down, nor get it closed again. I put the pump bypass back to operational, tried the top button again to no avail. So there I was with the top partially open trying to figure out how I was going to get the car to the dealer. I started it up, and then the top automatically retracted, and was fully functional again. Go figure.
mikeofmocity (06-10-2024)
99xk8guy
06-05-2023 06:28 AM
