How to adjust low beams
Look at the rear of the low beam and there's a plastic "stick" out of the back. Above that "stick" is a white plastic 6mm nylon nut that you can turn.
Look into the plastic window where the high beam and other bulbs are located. There's a level bubble and scale. As you turn that nylon nut you can see the bubble move to the front or rear of the car. The more the bubble is to the front of the car the higher your beam.
I've set my beam to the front of the red line. There's also a plastic scale near that stick towards the driver's side fender. That scale sets your beam to the left or right.
rsa760041
23
09-25-2015 01:33 PM
