How can I fix it ? Wheel Arch Lineer
Pop rivet a strip of aluminium across the inside of the liner where the break is.
You need to decide if you want to try to keep the horrible plastic fastener in which case you'll need a hole in the al strip big enough to let the fastener through and do some filing to make the slots the fastener locks into or do what I did and make a little al cage holding a stainless steel M6 nut which is held in place by one pair of pop rivets and use an M6 bolt + washer to hold the access panel in place.
Anything solid will do, you could use plastic and self-tapping screws (plastic + pop rivets probably not a good idea).
When you order the 'trap door' the fastener doesn't come with it - great idea eh!! so decide if you're going to try to resurrect a fastener slot (in which case order a fastener as well) or use a bolt.
I much prefer a bolt - far more positive.
ps - put your car details in your signature so we can help better.
Jag_Generation (04-29-2012)
Jag_Generation (04-30-2012)
One of the remoter outposts of Jag World!
I drove down to Lucca last summer and have driven to Amalfi in the past but never got as far south as the boot.
For new XK8 wheelarch liners:
GROWLER JAGUAR PARTS - XK8 & XK (New)
LH and RH liners are about half way down the list in the right column.
Two specialist UK Jaguar breakers:
JoJags Direct The UK Number One Jaguar Outlet
EuroJag, The Premier Jaguar Parts Supplier.
There are several other Jaguar breakers in England but these are probably the largest. Both have been advertising XK8's in for breaking recently.
![Icon Lol](https://www.jaguarforums.com/forum/images/smilies/icon_lol.gif)
hunter34
19
09-14-2022 11:09 PM
