How to check your ECM ground
Apart from a bad battery one thing to suspect when odd codes get thrown is a bad ground somewhere.
It might help to know that the OBD port pin 5 goes to ground via the ECM while pin 4 is grounded directly.
Pin 16 is battery volts so you should see the same voltage between 4 + 16 as 5 +16, and the resistance between 4 +5 should be a fraction of an ohm.
![](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/34459-how-check-your-ecm-ground-30711-who-has-modified-their-own-ls1-harness-obd-ii_pinout.jpg?dateline=1361613125)
The following 13 users liked this post by steveinfrance:
berlin1977 (02-23-2013),
BobF (02-23-2013),
britannia (02-24-2013),
GordoCatCar (02-24-2013),
heima (02-25-2013),
and 8 others liked this post.
rsa760041
23
09-25-2015 01:33 PM
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
abonano
25
09-25-2015 10:43 AM
