HOW TO: Cleaning the Wheel Speed Sensors FAQ
#181
OK, I think I might have (at least) started to fix the issue...
As I couldn't get the front wheel speed sensors (or as my local official Jaguar garage called them, ABS sensors) off, I took it to a local (non Jag) garage, who managed to get them off, clean them, clean all around the area and now the car seems to drive fine, with no flashing DSC warning light, and no limp mode...
However, the ABS and DSC lights are still on, but I don't seem to have any issues with the car itself in terms of driving...
Could it be that these lights simply need to be reset? Once they are on, only a reset (by a Jag diagnostic tool, or similar) will switch them off?
I do have an AutoEnginuity OBD kit, which I believe has the ability to switc off warning lights...would it be safe/a good idea to switch these warning lights off, seeing as the car seems to be driving fine now?
Thanks for all the help!
Kevin
Kevin
#184
#185
OK guys, here are the results of my wheel speed sensor cleans, and AutoEnginuity dignostics...hopefully, it might shed some light on my issues!
Timeline:
1. I cleaned my rear wheel speed sensors, and had no effect on my problem.
2. Took to my local (non Jag) mechanic, who removed and cleaned the front wheel speed sensors, which seemed to fix the issue I had, but the warning lights remained on.
The first picture is a photo (sorry about the quality) of the AutoEnginuity diagnostic after the front wheel sensor cleaning, but before I cleared the fault data using the AutoEnginuity tool.
I then cleared the fault data and the second photo is after a new scan using the AutoEnginuity...
So, thoughts anyone? Are the faults likely to come back, and have I simply masked the problem?
Much appreciated
Timeline:
Much appreciated
#186
#188
I must add this comment to the "Cleaning WSS" dialogue:
For many months it seemed that cleaning my WSSs did make a difference. However, I had other weird symptoms - such as the ABS/DSC warnings coming up when I made a sharp turn while backing the car.
What I finally figured out was that is wasn't the cleaning the WSS that was making a difference, it was re-connecting it! Apparently, the electrical contact inside the connector wasn't completely reliable, and after a few weeks of driving, the connector would dislodge ever so slightly and start giving me warnings again. The cleanliness of the sensors had nothing to do with the onset of warnings.
To fix this, I very, very, very carefully bent the pins in the sensor just a little. Then I carefully replaced the connector, making sure that the pins were entering their little sockets and not being crushed. I did this several months ago and haven't had a problem since.
#190
The P1000 would change to P1111 only after a Drive Cycle.
Your post indicates that the P1111 is present before a New Drive Cycle?
#191
Hmmm...you're not as confused as me!!
I am not really sure about codes changing, but basically, I was running the engine, scanned using the OBD and it returned the first set of results.
I then hit the "clear fault list" button on the OBD kit, and switched the engine off.
I then re-started the engine, and re-ran the scan. The result was the second picture (and my ABS light was now off).
I haven't actually driven the car during the whole process...merely started it.
#193
OK, drove the car, and the ABS & DSC warnings came on within a few seconds....Not too surprised by that!
Here is a photo of the re-scan after the drive...
So, could I deduce from the re-scan that the issue appears to be with the Front Right Wheel Speed Sensor?
My next step (if this seems like the correct step?) is to buy a single WSS and replace the front right and then clear the warning lights and drive the car and re-scan...
Does that sound like the obvious thing to do?
To make it easier, does anyone know what the part number if for a 2003 XKR wheel speed sensor?
#194
I wouldn't buy a $en$or yet. Bad wiring can mimic a bad sensor, is more common, and a lot cheaper.
Swap the LF and RF sensors, clear the codes and drive some more. If the fault stays where it is, the wiring is the prime suspect. If the fault moves with the sensor, that's the bad guy.
Good luck.
Good luck.
Norri (05-05-2014)
#196
Good luck.
Good luck.
Report back here after the drive, you've nearly fixed it !!!
#198
Check your wires
On mine it was the wires. Similar symptoms, the action of "cleaning" was reconnecting the wires. On inspecting the joint between the wire and the plug, the insulation was open and the wire was not all there!
Jaguar could have added much longevity with a 10 cent strain relief right there, but oh well.
I developed a cheap fix for the wires, if they are bad:
https://www.jaguarforums.com/forum/x...re-fix-114732/
Marc
Marc
#199
#200
OK guys, another slight update to the problem (ABS light on and DSC warning with above scan code and warning)...
I replaced the "faulty" right wheel sensor, and now I get the following error message...
C1142 - Front right wheel speed sensor tone ring tooth missing fault
I can't see much (any) info on this...can anyone shed some light on this one please?
Car still drives, but after having cleared the ABS and DSC warnings, they re-appeared after about 10 seconds of driving.
Thanks! I'll get there in the end!!
Cheers,
Kevin
Cheers,
Kevin
