How to disable convertible top......
Can anyone suggest the best way to disable the convertible top in a 2001 XK8 ? What is the best way to do this....the reason is, I do not want the top being lowered by anyone else but me, and the manual makes reference to several fuses..(under the hood, under the dash, in the trunk....etc.) but I'm not sure which one is the most appropriate one to pull. Or if there is a better way to do this.....what would it be ? I want to disable the "Roof" switch directly under the radio, so that the top will not go down when engaged.
I know it sounds weird....but any suggestions ?
Thanks!
Thanks!
Thanks!...One more question...is it also okay to disconnect the connector at the Hydraulic Pump above the cd changer in the trunk to achieve the same result ? Or is pulling the fuse a better option...
Received 2,192 Likes
By doing this...will it also reduce the possibility of the hose leaks that are so common to convertibles ? (by the way Thanks so much for your advice)...
Edit: just thought of this ... If you go this way, do not hold down the top up/down rocker switch for extended periods. The hydraulic pump will be flailing away trying to make things move, and all of that energy can go nowhere else other than heating the pump and the hydraulic fluid. Something on the order of 10 seconds would not be a problem; something on the order of a minute, not so good.
vinny jones
10-05-2015 07:20 AM
FS[Western US]: Jaguar xk accessories for sale
jfitzoz
09-07-2015 04:28 AM
