How do I check my clock?
The clock in my 98 XK8 seemed to stop working. Now it works but when you push the re-set buttons, bothing happens. Is there a way to check it out? I thought a wire may have been loose but my mechanic has checked and all seems to be ok. It worked one day and then it didn't. I also have lost the little green light that shows the side marker lights are on as well and he can't seem to figure that out either. HELP please
![Icon Gunhead](https://www.jaguarforums.com/forum/images/smilies/icon_gunhead.gif)
If the clock is working but just the time set buttons are not, then there is a fault in the 3-gauge cluster itself. I cannot say for sure, but this type of fault may be repairable if you could remove the cluster and send it to me . Otherwise used 3-gauge clusters run about $50-$100 on ebay. All years are interchangeable for the XK8.
If it is the green blinker light that is out there is a light bulb that can be replaced pretty easily from the back of the instrument cluster. If instead it is the rectangular green light with the headlight symbol, it is probably a light bulb also, but the instrument cluster must be opened up and partially disassembled to access it.
1964Daimler
09-09-2015 11:28 AM
