How do you split open the rear view mirror
i did a 96 xj6[they should be the same type unit].i found a good mirror in an engine fire car,the plastic housing was damaged.i had nothing to loose so i pryed the case where the seem is and it came apart.use a sharp putty knife an start at the top or bottom,not the sides cause theres no give.work it back and forth gently till you hear it unsnap,then proceed around the circumfrence...steve.
99xk8guy
06-05-2023 06:28 AM
