How to get moisture out of the spark plugs?
Hi!
I had problems with coolant level sensor and in the end it was the magnet in the expansion tank that was stuck.
I think I was bit too careless with water and got moisture in #8 cylinder spark plug because now I'm getting fault codes p0308 and p1314. Engine idle is quite harsh.
How would you advice to solve this problem? Would spraying lots of CRC 5-56 or WD40 help get moisture out without disassembling anything?
