How hard to install new shockson XK8?
Guest
Posts: n/a
RE: How hard to install new shockson XK8?
The project is much more complex than just jacking up a car and removing the shock.
On the fronts you need to remove the upper A arm by pulling out the fulcrum nut. Not terribly difficult, but you must be careful to keep the shim placement exactly the same when you reassemble. These shims set your caster. They can also be very reluctant to reinsert as you feed the fulcrum bolt back into its location. Once you get the hang of it, it moves pretty quickly.
XK8 shocks are part of the spring assembly. You also need a good spring compressor, and I dont mean the $29.95 model from Summit Racing. You need a good professional model.
I dont know the rears. Hope this helps. gordo
99xk8guy
06-05-2023 06:28 AM
aholbro1
08-05-2021 05:02 AM
