How many clicks on handbrake ratchet?
Recently changed the rear brake discs but have to go back in to replace the handbrake shoes as the liners fell off one . So how many clicks is normal on the handbrake? Currently, struggle to get it to one .
As handbrake not been used since the MOT test 8 months ago I cannot remember how far up it comes .
Sounds like your cable is out of adjustment ...probably stretched...the brake pads dont wear ( no rubbing) or the drum adjuster move so I think its get under and let someone pull on the handle and see what movement you have in the cable.
On mine the linings became detached from the shoe due to rust under the lining but only on one side.
I would check the cable first.
