How much to budget for maintenance costs for an XKR?
I'm thinking of buying a 2004-2005 or so XKR coupe with about 30k miles. About how much would I have to expect in maintenance/repair costs per month? By the way, I will drive about 1200 miles a month.
I hope it's not much more than $100-150!
Are you doing the work yourself ? If not, don't buy this car as the Jaguar dealers in my area charge $145/hr labor. They charge 1hrs labor to just diagnose the problem, even if you tell them what it is. Parts from dealer are just crazy prices example I needed an O2 sensor they charge $605 per sensor. I got mine on eBay for $65 each. People have paid $900 for transmission fluid change, I did it for $105. So as you can see if you cant do your own DIY and the car is not under warranty I would stay away from high end cars in general i.e Porsche, Jags, Mercs, Audi.
I have an Audi A5 2010 Quattro, S-Line + all options Dealer said they had a maintenance deal for all the services to 35K. Which if you check the manual is 4 oil changes. Their deal $750!! I just bought the Oil and filters for the first 2 at a cost of $93.
Are there good independent Jaguar mechanics in most areas?
I have had a 2005 XKR coupe for almost three years and I have not found it much different to care for then any other vehicle I have owned. Key factors: Buy your parts online as there are several good sources (very big savings). Practice good preventive maintenance. Locate a good Jag tech/mechanic. Don't drive the car like a hotrod and participate in this forum. The XK8/XKRs are outstanding cars and they are a real bargain in todays marketplace. Of course find a good car to start with.
Regards
Tim V.
Regards
Tim V.
I had a 98 XK8 coupe for about 4 years and have had an '05 XKR coupe for 1 year. Although my R had a few more problems, maintenance costs were about the same. Like it was mentioned before brakes and rotors are going to be considerably more with the R and handling package. I also think some suspension stuff is more as well, but much of the car is the same as an XK8, or an XJ for that matter. And what was also said, if you can do much of the work yourself you will be roughly even. I'd go for it, its a wonderful car, but an R is much sportier -- ie rougher ride than the XJ. If that is what you are after, than that's fine, but if luxury touring is what your after than it can be harsh.
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
Yup even though I hear peoples horror stories I've owned my car since 2004 and only problem I've had is an O2 sensor ($65 each I changed all 4) go and thermostat $56. I have done a lot of preventative maintenance, trans fluid, brakes, coolant, 2nd tensioners, belts, 5K oil changes, fuel filter, air filters e.t.c. I do very little miles as I work from home i.e. 24K miles since Fed 2004.
I love the car and nearly sold it a few months ago but could'nt let it go LOL I will keep it for at least another 2 yrs then get a 2010 XKR or Aston Martin.
If these cars start to become collectible and I think they will because they look so great then you will not be able to pry it from my oily hands!!
Wolfy
05-28-2024 08:06 AM
innzane
09-02-2015 10:08 AM
