How precise should the steering be?
I have had the XKR for a while now, gone through a few tanks of gas, and starting to get to know her.
Generally, the suspension - while a bit on the soft side - is quite good with no clunks or creaks, and the setup feels fine for such a heavy car. The steering doesn't have me 100% convinced though.
When the steering loads up it has good feel; however, until then it isn't as precise as I would have wished. Unloaded straight ahead is a little vague and the initial turn-in response is not very sharp - although it improves when going for the curves more dedicated. It is not a match for my Alfa on the twisties (although it murders it on the straights).
Is this typical behaviour for the steering, or an indication of something that should be attended to? I am aware that it is a heavy GT rather than a lithe curve-tool, and overall I am very pleased with the car. Just want it to be the best it can be.
Thanks for any comments,
Lars
Lars
I sympathize, but it's probably normal.
I came from driving a Porsche Boxster to an XKR coupe that needed maintenance.
The Jag should not feel bad or sub-par. If it does, you can be sure you have maintenance issues.
BUT THERE IS A SIMPLE ITEM TO TRY TO SEE IF YOU LIKE IT BETTER
Driver side fuse box, first column, third fuse from the top.
Remove it. The steering will be heavier. I love it.
However, with the fuse removed, you also disable the climate control completely.
Try it.
I drove that way for 12 months before having a switch put inside the glovebox that accomplishes the same thing but leaves the climate control enabled. If I had not discovered this trick, I would have sold the car.
Here is what others told me:
Alternatively it can be accessed at the steering module (module with a 9-pin connector, behind the glovebox). On 2000-2006 vehicles it is the blue wire, connector pin 4.
Paul Pavlik clarified further:
The Module is located on a Bracket mounted to the Right of the Glove Box (LHD Cars). To Access, remove the Glove Box Assembly.
If you install a Switch that interrupts the Blue Wire, the Steering will be "Easy" or "Low Boost" at all times when the Switch is Open. When Closed, the Steering will change Boost with Speed (Factory Setting).
To enable "Hard Steering" or "Low Boost" at all times, you could install a Switch in series with the White/Blue Wire feeding the Module. With the Switch Open, The Steering would be "Hard" at all times.
Voltage to the Rack Solenoid causes "Low Steering Effort" or "High Boost".
No Voltage to the Rack Solenoid causes "High Steering Effort" or "Low Boost".
Try it.
The following 3 users liked this post by weisberg:
Great post and idea, weisberg.
I've noticed some play in my steering as well- I came from a Porsche 944 Turbo before my XKR recently, and am inspired to make the XKR as much of a dialed-in driver's car as possible. I've got nice Continental DWS Z-rated tires on there which helped, but also need to look at my bushings, control arms, doing an alignment asap, and definitely try the steering rack boost trick.
They reported the same condition,
Artigiano,
Keep after it. I have a 63 Alfa spider as well as an XK8 coupe. Oddly enough both have just over 94K miles on them. After a very capable dealer chased down all the clunking noises in the XK8 suspension, replacing sway bar bushings, struts, etc. and with the Michelin pilot sport tires (with incumbent wear issues) or good Pirelli's, I would put the jag just slightly lower on the handling than the Alfa, on par with the wife's 2006 BMW 325i. This is just due to overall mass - the Jag is heavier, the BMW is heavier and taller. The handling is very precise on all three.
The 63 Alfa in question is from the days when the convertibles were very stiff bodied. The XK8 convertible and your Alfa are real similar with respect to body torque issues so I would expect a similar set of issues when hitting railroad tracks with one wheel first but the steering and suspension on your Jag can be very precise when it is dialed in right. There should be no delay or mushiness.
At the same time, I have to admit the Alfa is a car you just have to think about going a particular direction and it goes that way, effortlessly. They just have such prima donnas on their web sites that I refuse to join them.
Good Luck, let me know if there are Alfa resources you need.
-Steven
-Steven
Thanks; imagine, a fellow Alfa/Jagnut! A 63' would make that a Giulietta/Giulia? Nice car!
Thanks for the useful comparisons. I imagine the Jag is only a four-wheel alignment and possibly new shocks away from its best. I agree that the Alfa seems to be connected to curves by telepathy - great fun!
Haha - seems the prima donna bit comes as an integral part of Alfa ownership. Do I smell an underground sub-thread forming?..
Lars
They just have such prima donnas on their web sites that I refuse to join them. Good Luck, let me know if there are Alfa resources you need.
Lars
