How to remove the dash veneer (centre section)? FAQ
Old 09-11-2014, 07:18 AM
GGG is offline
Received 16,851 Likes on 12,186 Posts
No, but I have a diagram:
Be careful handling the clips - they have teeth!
Attached Thumbnails How to remove the dash veneer (centre section)? FAQ-xk8-veneer.jpg
Old 09-11-2014, 03:11 PM
worrasf's Avatar
Originally Posted by steeevo
Has anyone got a photo of the trim once removed so i can see where the clips are on the back as i cant seem to get mine off and its completely different to the piece rev is removing in his jag
Here you go.
Having done this a few times fitting, removing and refitting my 3-guage conversion it's very straightforward. I have found when replacing its easier to pre-fit the clips to the upper pair but to push the clips into the dash first for the lower pair. Make sure you expand the clip a tad so it grips in the dash cutouts and also push the teeth inwards so they grip the tangs on the trim snuggly.
On a different topic I have decided to get my centre panel vinyl wrapped - there is a pro-shop a few miles away specialising in full car wraps as well as trim. I'm going to get it done in black like the photo but just plain satin non-textured so it will match the air vents and centre console switches.
I've pretty much given up on finding a full set of matching veneers at a reasonable price.
Steve
Attached Thumbnails How to remove the dash veneer (centre section)? FAQ-img_0255.jpg   How to remove the dash veneer (centre section)? FAQ-img_0253.jpg   How to remove the dash veneer (centre section)? FAQ-photo.jpg
Jpav27
07-31-2022 06:43 AM
jagent
09-12-2015 01:40 AM
1964Daimler
09-09-2015 11:28 AM
mrplow58
09-09-2015 11:27 AM
Saturbo
09-08-2015 07:35 PM
Quick Reply: How to remove the dash veneer (centre section)? FAQ
