how to remove front shock
I have been following JTIS when I went to change shocks and springs and JTIS says to remove upper A arm fulcrum bolt and move aside to manuever shock out.
A member said it can be done without touching the A arms. And I did it
1 remove fender liner
2 remove nuts on top
3 remove shock bolt below and stabilizer link bolt
4 maneuver bottom end out of position
5 clear shock mount from body
6. rotate assembly with top to rear of car
7. remove
7. remove
The following 3 users liked this post by volkris:
7. remove
7. remove
Pristine97XK8Convertible (06-26-2020)
