How to remove leather door panel?
I'd like to remove the leather door panel that is just above the arm rest. This panel is elongated and covered in leather but the leather is coming off the panel. I'm assuming it will just pop off with the use of a panel tool, but I thought I'd ask before breaking something!
cjd777 (10-07-2018)
I assume door card is the entire inside door trim? I did look at a Youtube video by Sam that showed how to remove the door panel but I was hoping that small panel above the arm rest could be removed from the front. If you are talking about the entire door piece, can you remove this panel from the back side? I will need to remove it to install clips or glue the leather back on. Please send what you have!
Just to be clear, this is the panel I am referring to. Also, the arrow shows where the leather has detached from this panel. This is what I would like to fix.
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/640x480/img_4917_c11a44596b5565e103a84d4be2b7e2dd0e02cc51.jpg)
Texas bill, even if the answer is yes - there is a way to remove the leather without removing the door card - and I don't know if that's true, Bill pulling the door card is so easy IMO it just doesn't make sense not
to do so.
If you pull the entire door card, you'll have access from so many different angles and you can take it to your work bench.
Bill it is a 5 minute job, maybe 20 the first time.
So, sorry but no, I don't know if you can work the leather with door card installed.
john
to do so.
john
Johnken (10-07-2018)
I decided to remove the passenger interior door panel to replace the gaskets around the exterior handle (rubber oval around handle). 5 minute job huh?? I've spent the last 30 minutes trying to remove the small plastic screw cover under the interior door handle to get to the screw. I've tried all sorts of screw drivers, but it is impossible to get enough angle to pop it out. I've tried small pick tools also with NOTHING removing that small plug. I've watch the video and for Sam, it just "popped" out. No luck here. Any advice?
Sure, I used a dental pick the 1st time to pop the screw cover off. If you don't have one of those, grab the smallest flat blade (jewlers screw driver?) You can find.
with either tool, look for the tiny indent around the screw cover. Press the tool in, lever the cover out. Twist the flat blade to wedge the plug up millimer at a time to get a grip. Heck, given the price of pne of these screwdrivers (cheap) you could put it in a vice and bend the end of the flat blade to provide more leverage.
of course, keep the other hand to block the cover from shooting off into a haystack. Hint: after battling that the 1st time I put the plug in backwards. It'll stick up a bit (good leverage for next time) but no one without a magnifying glass wil l ever notice.
you know, as i typed that last paragraph it occurred to me: if backwards = one side wil l stick up a bit, then that could be part of removal difficulty. It comes out at a small angle, not straight in and out! Well keep that in mind and let us know how you do.
John
John
thedigitel
09-10-2019 12:35 AM
adulit
05-08-2014 06:39 PM
jahummer
05-20-2011 04:49 PM
