How to remove "R" shift knob?
I had to take mine off to replace the dial plate. The knob is simply screwed on to a thread at the end of the shifter stick.
Mine was so stuck that the knob separated from the long nut inside when I turned it counter clockwise to get it off. I had to remove it by turning it until the nut came out of the knob. From here I could remove the nut from the shifter stick. There was very little damage to the inside of the knob. To replace it, I simply glued the nut back into the knob and screwed it on again. . Works perfectly
-Baywin
-Baywin
Stamford (08-22-2017)
+1 with Baywin. Look for the wrenches flat spot on the black metal stylized nut below the knob. When assembling you screw the wood knob down and this nut up. When the R wood knob is just about all the way down and is properly oriented the nut comes up from the bottom to lock the knob in place.
Hypothetically they may have left a few threads showing below this nut. In which case you could cover it in masking tape to prevent scratches and use a adjustable wrench to screw it downwards loosening the opposing grip on the wooden R knob.
John
John
