How-to on removing rear exhaust section?
I have bought a pair of straight-through pipes to replace the rear section of the OE exhaust (basically to get more noise!). I had a quick look under the car yesterday and managed to loosen the appropriate nuts and bolts, but access is not easy (car is on axle stands, wheels removed).
Is there a how-to on swapping these pipes over? TIA
Not that hard, I did it yesterday! Once you have loosened the clamp nut/bolt, give it a sharp tap with a hammer to release it, pull the exhaust of it's front mount, as you have a 2005 you might find it easier to undo the bolts holding the mount in place.
Once it is off the mount twist the exhaust downwards, as long as the tube has released on the clamp it should pivot quite easy, then keep twisting back and forth until the exhaust comes off the slip joint.
Easy
Easy
davidladewig
09-03-2015 06:32 PM
