HOW TO: Repaint door molding trim FAQ
Old 05-31-2011, 03:04 PM
K.Westra's Avatar
Lightbulb HOW TO: Repaint door molding trim FAQ
A while back the door molding trim on my car started to peel. It quickly got worse until it reached this state:
After doing some research I discovered the proper paint to repair this is Dorchester Grey 342/LDP, but WhiteXKR suggested another alternative, Graphite Duplicolor Wheel Paint:
Buy Duplicolor Wheel Coating, Graphite, 11 oz. Aerosol HWP102 at Advance Auto Parts
I thought I'd save a little bit and try it out.
Here are the steps I took to respray this area.
Step 1:
Although these pieces can be removed, I found it easier to leave them in place. This meant everything had to be masked off:
Step 2:
Carefully sand as much of the existing paint off as possible, using sand paper designed for use on metal. You shouldn't need anything too aggressive, I used 200 grit and probably could have used something less aggressive.
Once you finish sanding, clean the area with some isopropyl alcohol.
Step 3:
If you are using the actual Dorchester Gray, you will need to treat the aluminum with a self-etching primer. An advantage to the Duplicolor wheel paint is it is designed to work on unprimed aluminum, so I didn't need to prime. Give the area a few nice, light coats of paint allowing about 10 minutes between each coat.
Here is after one light coat:
Step 4:
Next up is the clear coat. After giving the last coat of paint 10 minutes to dry, give the area a few light coats of clear, with 10 minutes of dry time in between.
Step 5:
After the final coat has been given time to dry (but not too long) carefully remove the masking and enjoy.
As WhiteXKR said, the shade of gray is very close, but the metallic flakes are larger (and reflect the sun a little bit more as a result) It is tough to see in the picture, but the door has been resprayed and the rear window trim has not. I may go back and spray the rear window trim, simply because it is a bit noticeable when they are placed side by side. For under $20, I believe the two cans of Duplicolor is the best route.
The following 13 users liked this post by K.Westra:
1vorjagman (04-03-2018), 2002XK8Orlando (05-31-2011), ccfulton (07-06-2012), dannyS (08-21-2013), Felipe Pr (06-01-2011), hlgeorge (05-31-2011), Jag Pilot (12-07-2013), JimC64 (05-31-2011), lovemycar1 (12-15-2011), Orthodixie (02-25-2018), Stamford (12-13-2011), stevearrari (07-08-2016), WhiteXKR (05-31-2011) and 8 others liked this post. (Show less...)
Old 05-31-2011, 05:06 PM
Fedoraja1's Avatar
Very cool Keith! I'll have to try this soon! Thanks for the tut!
Old 05-31-2011, 07:17 PM
hlgeorge's Avatar
Gee Keith, you must sweat a lot of toxic sweat! I don't have a wear problem on mine!
Old 05-31-2011, 07:36 PM
WhiteXKR's Avatar
Received 2,985 Likes on 2,124 Posts
Nice write-up Keith!
I have exactly the opposite, did my rear window but need to get around to doing my door.
Old 05-31-2011, 07:51 PM
Received 9,007 Likes on 4,113 Posts
Nice one Keith, thanks so much for sharing
Nelsonsson (04-07-2015)
Old 05-31-2011, 10:50 PM
RCSign's Avatar
Keith
Nice write up, the only thing I would add is these trim pieces lift right off, very easy to remove.
Old 06-01-2011, 08:14 AM
K.Westra's Avatar
Originally Posted by RCSign
Keith
Really?!? That would have made it so much easier. I did a bit of searching and all I found is that they were difficult to remove and easy to damage in the process. Do you just pull upward?
Gordo (06-03-2011)
Old 06-01-2011, 12:21 PM
RCSign's Avatar
Keith I copied this from the JTIS
Remove door mirror. Refer to 76.10.52.
Exercising care to avoid damaging paintwork, lift and release waist rail moulding from door flange.
The rear window molding lifts off
I don't think you have to remove the mirror. I will check tonight, when I get home. I think you lift up on the molding on the back side of the door, and pull the molding from under the mirror.
I'll let you know later.
Old 06-01-2011, 12:35 PM
Cadillac's Avatar
Thanks on behalf of other XK owners
I am sure our dear friend h20 will sort this out at FAQs
Old 06-01-2011, 06:48 PM
K.Westra's Avatar
I checked the JTIS and tried on my car, and I can't get it to come out without removing the mirror and that seems like more work than it is worth compared to just masking.
Old 06-01-2011, 07:05 PM
H20boy's Avatar
Received 1,151 Likes on 753 Posts
Added to our FAQ thread, a good addition too.
Old 06-01-2011, 09:46 PM
RCSign's Avatar
Keith I went home and removed the window molding and re-installed in less than 30 seconds. the window molding only goes under the mirror rubber by about 1/4" It fits the spot welded seam at the top of door.
Lift up on the molding on the back side of the door, and pull the molding from under the mirror seal.
To re-install lift the mirror seal and insert under, and press down on. try the back window first and it'll give you an idea of how it attaches.
volkris (01-20-2019)
Old 06-02-2011, 02:51 AM
K.Westra's Avatar
I'll give it another shot later today.
Old 06-03-2011, 09:12 AM
K.Westra's Avatar
I still can't get it to come out. Maybe the rear part of the molding is too tight on my car? I can't get that part to pop out in order to slide it back.
Old 06-03-2011, 11:05 PM
RCSign's Avatar
Keith
I wonder if somebody may have glued them on. They shouldn't be that hard to take off.
You got them painted anyway, nice job.
Old 06-04-2011, 01:09 AM
hm1's Avatar
hm1
hm1 is offline
Is it true that the later 05-06 model years have black trim, as oposed to this graphite color in the early cars? It would be alot of work doing all the trim, but worth it.. Are these trims easily removed?
Old 06-04-2011, 10:38 AM
RCSign's Avatar
hm1
The trim is easy to remove see the above posts. try the back window first it will give you a idea of how it's removed
Old 06-04-2011, 02:01 PM
JeffereyGreen's Avatar
Hmm, on my 2002 XKR Convertible the trim is a metallic silver/gray. They same as the trim around the windshield and the base of the mirrors.
Mine was bubbling up on one side, so I had it repainted at a local shop. Worth the few bucks it cost. I had two trim pieces and both mirrors repainted for under $100.
Old 06-05-2011, 08:45 AM
keiron99's Avatar
I had a go at this last year. The paint on my trim was bubbling badly, apparently because Jaguar failed to use "etch primer" on the bare metal.
So I diligently rubbed down, etch primed, pt on base coat (rubbing down all the time) but no matter what I did I couldn't get a smooth top coat, and by the time I added the clear lacquer it just looked mottled and very much like a DIY job. I spent hours and hours on it. So I gave up half way through and now don't know what to do.
I was rather hoping I could find a pro to do it but I dare say I could probably buy new for what they would charge - which would probably be hundreds of £ or $.
Old 06-05-2011, 02:02 PM
K.Westra's Avatar
Try giving the wheel paint I used a try. I've sprayed quite a bit of different spray in the past and this stuff goes on really easily. Also make sure you do multiple, really light coats. Don't worry if the first coat doesn't cover completely (althought mine did) and go from there. At $12 for two cans (paint+clear), it is definitely worth a shot, even if it still doesn't work for you.
Quick Reply: HOW TO: Repaint door molding trim FAQ
