Hydraulic fluid pouring out of headliner
Yesterday I was driving and felt something warm hit my arm. It was the hydraulic fluid from the convertible top. The top won't work now, the back windows are down and the fluid absolutely poured out of the top and still continues to drip.
Is it just the lines that need replacing or is it the whole kit that I'll need to get? Any help would be appreciated.
thanks!
LJ
thanks!
LJ
There are a world of posts on this never resolved problem. Might start with this thread and I am sure a lot of folks will commensurate with you, me being one.
https://www.jaguarforums.com/forum/s...ead.php?t=5663
First thing, open the valve on the pump unit in the trunk to relieve the pressure so you can clean up.
I did this job myself (with the help of this forum) 2 months ago and replaced the lines for around $300. Otherwise your looking at around $1500 for a shop to do it because almost the whole interior of the car needs to be removed to replace the lines. It's a very labor intensive job. Keep us posted...
Hey Lisa--welcome to the club. Depending on the year and warranty situation with you vehicle, this MAY be covered under warranty. If you are in Glendale, there are a bunch of independent Jag mechanics in the San Fernando Valley that might be able to do the job for less than the dealer, or if you are handy and have patience, it is possible to do it yourself. I would recommend getting the improved hoses that were developed by another forum member (Gus). You will likely find his webpage if you start searching around for the hydraulic hose problem.
Doug
Doug
Sorry that you had the misfortune to experience the dreaded hydraulic leak that I call the green monster. It has a way of disrupting your life and your pocketbook. One thing to know is that you are not alone.
We have a great deal of information on the hyd system and you can read about it in this forum under the FAQ or you can go to my page at
http://www.gusglikas.com/AutoRepairHydHose.htm
http://www.gusglikas.com/AutoRepairH...lOperation.htm
http://www.gusglikas.com/RoofHoseReplacement.htm
http://www.gusglikas.com/AutoRepairJ...esRelValve.htm
I hope this helps.
I hope this helps.
Thanks everyone!! I think my husband and I will make the attempt to do it ourselves. Do you think we only need to fix the line over the windshield, or will be have to go from front to back? If so, is it hard to take out the front and back seats? Again, thanks to all of you for being "there" for me!!
You can find short hoses for the header but you will be doing it again because the repair kit leaks and has a lot to be desired. In face Jaguar does not use it anymore. Yes the recommendation and the only true fix is to replace the hose from front to back. The cause of this failure is that the hyd system puts out 1600psi and with the combination of the heat and pressure the hose connection fails. You can read about the hose and the pressure related issues on my page. As for the removal and install of the hose it is a big job and you can read about the process on my page.
That settles it. The top stays down on my new purchase until I can get that pressure reducing kit installed. Dear lord, why didn't Jag use stainless steel hydraulic tube and fittings for this??? I guarantee you if my interior has to come out I'm getting one of my Houston area control valve guys involved and we're going to hard pipe that baby.
I know that you are upset but a hard pipe is not the answer! If you do you would need a damper on the line along with a way to eliminate flex and vibration. Pressure reduction is the way to go! It will extend the life of your existing system. It would be impossible to guarantee no failures but you stand a better chance than without. http://www.gusglikas.com/AutoRepairJ...esRelValve.htm
But what probably would have been a vast improvement would have been for the line that comes from the latch to be solid until it hit the A-pillar instead of having these sensitive fittings right at the latch. Again, I wonder how (if?) the design was changed for the new aluminum-bodied XK?
Doug
Nothing's happened yet Gus I just took delivery of the XKR about a week ago and the top came down and stayed down since then. I've read your pressure reduction solution and I like it. I'm going to kick the idea around with some mechanical injunears I know down here and if they come up with anything interesting I'll let you know. Thanks for all that hard work!
Speaking of hard piping that system, have you seen a schematic for the hose routing and location of fittings?
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
BlacXJRcat
09-25-2015 06:43 PM
