hydraulic hoses
Took a first look at my hydraulic hoses, it says "power packer" on them. I read somewhere on this forum that some of 1997 had better hoses installed that are rated to handle the pressure. Am I in luck here?
![](http://i440.photobucket.com/albums/qq125/reko19/xk8/th_IMG_9036.jpg)
Also, it looks that the fluid was changed at some point to Pentosin and I just need to add it to the proper level.
![](http://i440.photobucket.com/albums/qq125/reko19/xk8/th_IMG_9038.jpg)
thanks,
thanks,
I believe that the 'Power Packer' hoses were better than the later ones but for more info than you ever wanted to know go to GUS's off-forum web site. http://www.gusglikas.com/autorepair.htm
Do you have a leak at the moment?
You need to read these two threads:
https://www.jaguarforums.com/forum/s...ad.php?t=27132
https://www.jaguarforums.com/forum/s...ad.php?t=42013
Don't think I have a leak, at least hope so. When I bought a car late last fall the guy tried opening the top but it did not work all that well, he needed to "give it a hand". I haven't touched it since. My plan is to refill the pump to proper levels, hopefully it'll do the trick and after that go with a V reduction method.
mikiep
12-20-2019 07:37 PM
