Hydraulic Top Hose Choices
Thanks for all the replies everyone.
I went with Top Hydraulics' hose set, and had one of the LSI pressure relief valves on hand when I originally ordered 2 for my car and knew one day my Uncle's car would do the same.
Not sure when I am going to perform the fix, but I plan on taking some video here and there with my GoPro when I do.
23,200 PSI burst pressure is AMAZING on those hoses.
srpope80 (10-20-2016)
Gus,
Thank you - your website is invaluable. I used it extensively the first time I replaced the hoses on my Silverstone as I got the green shower, rear quarter window regulator failed, and installed an LSI valve all at the same time...
The guidance and pictures fill in the major gaps (caverns) the FSM does not. If you're ever down near Tampa, please let me buy you a beverage of your choosing.
Me , none other than Top Hydraulics. The rear rams on my '99 XK8 were leaking. Header hose had been repaired by prior owner. I decided there is only one way to repair which is to do the complete system. Sent both rear rams, header latch to Top Hydraulics for rebuild with Teflon seals, better than new. Purchased the Kevlar reinforced hoses front to back from them as well. This is my second summer enjoying my drop top Jag. The service Top Hydraulics gave was fantastic. In addition, the replacement hose are a little thinner which made install at the header a breeze. I'm a believer. I am confident the repair is life time. Rich
Capped
Ordered 2 caps from Malone specialty.. Ive got 2 caps on now but they leak because there not metric but the top works great with exception to latches.
kmeseck
09-13-2017 09:25 AM
OUScooby
09-03-2016 08:50 PM
