Hydraulic Top Hose Choices
Old 10-19-2016, 09:33 AM
srpope80's Avatar
Thanks for all the replies everyone.
I went with Top Hydraulics' hose set, and had one of the LSI pressure relief valves on hand when I originally ordered 2 for my car and knew one day my Uncle's car would do the same.
Not sure when I am going to perform the fix, but I plan on taking some video here and there with my GoPro when I do.
23,200 PSI burst pressure is AMAZING on those hoses.
Old 10-19-2016, 10:27 PM
Gus's Avatar
Gus
Gus is offline
Received 2,214 Likes on 1,703 Posts
I have instructions on my page for both installing the LSI valve and replacing hoses.
srpope80 (10-20-2016)
Old 10-20-2016, 08:12 AM
srpope80's Avatar
Gus,
Thank you - your website is invaluable. I used it extensively the first time I replaced the hoses on my Silverstone as I got the green shower, rear quarter window regulator failed, and installed an LSI valve all at the same time...
The guidance and pictures fill in the major gaps (caverns) the FSM does not. If you're ever down near Tampa, please let me buy you a beverage of your choosing.
Old 10-20-2016, 04:28 PM
reb1999's Avatar
Me , none other than Top Hydraulics. The rear rams on my '99 XK8 were leaking. Header hose had been repaired by prior owner. I decided there is only one way to repair which is to do the complete system. Sent both rear rams, header latch to Top Hydraulics for rebuild with Teflon seals, better than new. Purchased the Kevlar reinforced hoses front to back from them as well. This is my second summer enjoying my drop top Jag. The service Top Hydraulics gave was fantastic. In addition, the replacement hose are a little thinner which made install at the header a breeze. I'm a believer. I am confident the repair is life time. Rich
Old 10-20-2016, 07:27 PM
rsims's Avatar
Default Capped
Ordered 2 caps from Malone specialty.. Ive got 2 caps on now but they leak because there not metric but the top works great with exception to latches.
Old 10-25-2016, 07:53 PM
rsims's Avatar
got the cap and plugs from Malone specialty. Fast and Larry was very friendly. The Wrench for latch and the rest works Great... Now my other Issues....
rs
Old 07-13-2019, 10:43 AM
Ktmscott's Avatar
Should Teflon tape be used on hose fittings?
  #28
Old 07-13-2019, 10:44 AM
Ktmscott's Avatar
Should Teflon tape be used when re installing hydraulic hoses on my convertible top. Had rams rebuilt. Re-installing hoses.
Old 07-13-2019, 08:03 PM
Dennis07's Avatar
It should not be used. The connections should not require any kind of sealant, but if you want to put something on there, use a paste with PTFE. Using tape always carries with it the risk, however small, of some fragment of the tape finding its way into the hydraulic fluid and from there to ... a place where it might cause trouble.
The following 2 users liked this post by Dennis07:
DavidYau (07-14-2019), Johnken (07-13-2019)
kmeseck
09-13-2017 09:25 AM
Wings
09-07-2016 08:04 PM
OUScooby
09-03-2016 08:50 PM
randyb
09-01-2016 02:08 PM
vdpnyc
08-30-2016 12:18 AM
Quick Reply: Hydraulic Top Hose Choices
