i can't sleep...2005 XKR
#161
The Camera-Man??
Billy Clyde
#162
Just got her back from the detailer. The body shop did a great job, no sign of the dent!
I also had them sand & re-spray under the lip to smooth out scrapes and did a dark ceramic limo tint after having the original tint removed...
The original black rubber gaskets around the door handles were well worn, so they removed them and did a clear silicone to maintain the monochromatic grey exterior...
Rear bumper had a very small 1/8" sag due to some missing clips, and those were replaced. Hood vents were re-painted.
#163
Bluefin, It's hard to keep those little scrapes from happening under the front Lip....Mine need some help there also!
I can't believe that the Silver Bullet looks even better than before but it does! Now for sure, "It's the Prettiest Jaguar in the World"! It really looks super! I was wondering where those Side Repeater Lights came from?
Billy Clyde in Houston
prettybluefin (05-19-2017)
#164
The coupe got a nice all over buffing, I bet your black would be really nice if you did that. It removed so much dullness, and now the metallic in mine is sparklier.
Also, I am gonna send you some Justice Brothers stuff to try soon. Message me your address. I really like what it is doing to my coupe. And I am averaging 17.5 MPG now, up from 16 when I got her.
#166
Bluefin, Great! I just broke my arm patting myself on the back! I had the 2005 XKR several years before I discovered the "Dipper"! I used my Mechanics XJR one afternoon and found that they dip automatically when you put it in reverse.......So, I tried it on the XKR and found that it works manually......Really needed it for my curving driveway when I'm backing out......Helps a lot!
#168
Happness is a
WAF & PBF, Tomorrow, I am concentrating on my Mesh Grill....It's dirty and is bent-in a little in a couple places....Going to power wash it and then straighten the dents and get my Chrome polish out and give it a good cleaning.......Then go back to the power washer to knock off the white stuff that was left....Must be Spring! Me cleaning and all......Oh, I forgot, I liked those Smoked Tail Lights on that Black Victory-Edition so much, that I had to order a pair.....Also, ordered those Lumen LED Bulbs that wont turn on the "Check Tail Lights" warning.....Hope they work! I let you know and if I can remember how to send Photos, I'll do that too!
BC in Houston
BC in Houston
#170
WAF, I will send you a PM about this...When I get the Lens.....as I'm not sure if they have anymore...They have a Jaguar part number but not sure of availability....after 10 years! I will contact my Guy...Today!
BC
BC
#172
Rewiring?
Change your brake pads to ceramic, your wheels will thank you as well as your detailing time.
The center console has no room under it for expansion however the cassett holder is a snap in piece that can be removed, take the top off and the inside box will come out, you'll see how to remove the cassett holder.
Search for the antennae switch mod, while you have the console apart install the antennae switch, this keeps the "alien beacon antennae down when using the CD player, you can also wire in an aux input for MP3 players.
I wired my front fog lights to be on anytime the car is on without headlights on, great for viability. I also wired my rear fog lights to work as brake lights, again great visibility. Let me know if you want instructions, both are very easy to do.
Nice looking Jag, to bad it's a coupe...
Interesting! Could you post your wiring as a new thread?
#173
Jandreau,
If you would, please post these wiring instructions so that all of us might use them....I'm interested in the rear Fog Light becoming an additional BRAKE LIGHT.....but I'm sure that others would like the Day Time Running Light idea.
We all appreciate your time!
#174
Spray Paint for Tail Lights
WA, It looks like PBF has solved the Tail Light problem.....You can do it yourself and save all those bucks that I just spent....Assuming you saw the U Tubes about the Plastic paint!
You can Tape off the Clear area at the top and cut out 3 circles the size of the openings for the lights and then spray the smoke paint over the rest of the Lens...Don't paint it real heavy....just smoke it. I was going to do the same thing to the inside but you can't get inside to do it......This is the answer and I wish now that I hadn't ordered all that expensive stuff.
Now if I can get this guy named Jandreau to send us the wiring instructions, we'll know how to set-up the second Brake Light.....
BC in Houston
BC in Houston
#175
are the factory VE tail lights tinted plastic or are they smoked? (painted)
IF they are tinted plastic, they will look much nicer and last a lot longer than smoked ones
#176
2006 XKR Victory-Edition w/Smoked Tail Light Lens
2005 XKR w/ Regular Tail Lights Lens
2006 Victory-Edition Smoked Tail Light Lens
WA & Pretty Bluefin, Attached are the Photos I've been trying to send for the last 2 weeks....The Smoked effect is from the inside of the Lens but as I said, you can't get the Light apart to paint the inside, so you would have to mask-off the clear area for the Back-up Light and Blinker and the 3 Circles for the Brake, English Fog Light and Tail Lights. Then hit it with a light spray of the Plastic paint they use to smoke the whole taillight with..
I think you could almost duplicate (from a short distance) the Victory......
prettybluefin (05-31-2017)
#177
I will have mine done in a week or so, I am going to smoke the entire lens dark grey...
check out this animation.
#178
Bluefin, It will probably look real good with the Silver car......Looking forward to a photo of the change....Just hope you don't get a bunch of Tickets!!
Billy Clyde
Billy Clyde
#179
My post was #51 and I have comparison shots of the old lights versus the new ones. Somehow to me the tinted lights made the car look more "current".
Doug
#180
There is an entire thread on this https://www.jaguarforums.com/forum/x...n-98011/page3/
Doug
Doug
